Wills Mini Special
320 replies to this topic
#271 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 04 September 2014 - 02:45 PM
Close outs done and dusted, i have redone the paint in the picture where the burnt paint has been dusted over.
Flitch to redo on the l/h side then on with the front.
#272 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 09 September 2014 - 07:15 PM
So after having already fitted one flitch repair on the l/h side it all had to come apart as the flitch i had fitted on the r/h side had a flute in it. The l/h no flute. Bugger.
So new flute is now in so nothing like doing the same job twice. Not for the first time on this car either.
Now that was the last job with the car on the spit so off it came and the car is now back on the trolley all ready for the front subbie to go on tomorrow.
Quick clean up in the boot, filling a few pin holes previously missed and refitting the fuel tank strap bracket.
#273 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 10 September 2014 - 07:01 PM
Front subbie in with all new fittings so on went the panels for a looksee and not too bad
The door needed a bit of tweaking at the front so the A panel gap looks quite good. It will change a bit once its actually been fitted properly.
#274 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 10 September 2014 - 07:03 PM
Did you need to slot the door hinge holes?
I am just fitting my doors and I have needed to slot mine; was wondering how you got on?
#275 deepee71
deepee71
  • 101 posts
Posted 10 September 2014 - 07:05 PM
Looking sweet Neil!, cant wait to get mine off the spit and get the front end on...
Andy
#276 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 10 September 2014 - 07:10 PM
Both sides were already slotted but i have had to adjust them a bit more to get the fit i wanted.
Andy
Its feels like a major milestone Andy, its just all of the faffing around now to get things to fit. Need to break out the self tappers.
#277 deepee71
deepee71
  • 101 posts
Posted 10 September 2014 - 07:14 PM
To be honest I have used a Magnum wing and A panel, and used a Magnum door skin and at the moment everything seems to line up pretty good!,  time will tell once I get it off the spit and try it all together with the original repaired bonnet and  new front end.
Andy
#278 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 10 September 2014 - 07:20 PM
These are all Heritage panels, the A panel is not the best but will fit nicely once i have finished with it.
#279 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 10 September 2014 - 07:27 PM
Glad its not just me :)
How are you going to finish the top of the "A" panel? I have seen some left untouched (which I like), some are filled and made to disappear and some are welded along the top? If I leave the top of the panel will water get in and rot it out?
#280 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 10 September 2014 - 07:44 PM
I always weld them up then use my die grinder and carbide burr to shape the top to match the door swage line and the wing to scuttle line. No water getting in there then.
#281 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 17 September 2014 - 09:40 PM
Slaved the wings on to gap the bonnet and ended up with this
A little tweaking to do but not a lot.
Then onto the the A panel and door gapping.
 Not too shabby but the door fouled so after much tweaking and beating of metal ended up with this.
 again some final tweaking and adding a little more weld to the door edge to even things up a tad more
back of the door
#282 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 18 September 2014 - 07:11 PM
these gaps will be perfect by the time you've finished
#283 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 18 September 2014 - 07:22 PM
So after some more tweaking and bending the l/h A panel is on and the door fits really nicely
Then it was on with the front panel and the marathon welding session that will be the wings.
Probably another days worth of welding and grinding to do followed by the big seal up.
#284 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 19 September 2014 - 01:36 PM
Nice gappage  :highfive:
#285 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 19 September 2014 - 01:57 PM
Agreed  :-)
