Wills Mini Special
320 replies to this topic
#241 Marco1972
Marco1972
  • 822 posts
Posted 07 August 2014 - 08:21 AM
That door step looks great
Any idea when they will be available mate
Really don't want to fit the magnum one to my car !!!
#242 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 07 August 2014 - 03:21 PM
I do have another set as it goes.
#243 deepee71
deepee71
  • 101 posts
Posted 07 August 2014 - 05:17 PM
Enjoy seeing your updates Neil, would like to get hold of a couple of those doorstep pieces myself?.
Andy
#244 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 07 August 2014 - 08:54 PM
Onwards with the flitch repairs, top sections cutout and replaced.
The lower flitch section repair panel is no good, its got a pressed flute in it so i had to make a new one from scratch.
#245 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 August 2014 - 08:56 PM
Looks like wood effect steel there Neil!
#246 deepee71
deepee71
  • 101 posts
Posted 07 August 2014 - 09:02 PM
Was the flute added to the later models.... My MK3 doesn't have them on the original flitch panels...
#247 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 07 August 2014 - 09:03 PM
Not quite Ben, i had to cover the whole sheet of metal in Krust to keep the surface rust at bay. Our workshop is not the driest building in the world but im working at making it dry.
#248 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 07 August 2014 - 09:05 PM
I believe so, the repair panel i bought for my 75 Clubby was fluted as well so that i had to panel beat that flat as well.
#249 DiscoDarren
DiscoDarren
  • 136 posts
Posted 08 August 2014 - 01:48 AM
My '93 has the flute in. I've just used the magnum panel on that and it fitted quite well. Just needed a bit of adjustment on the lip that folds under and joins to the floor. Don't think i will be so lucky when I do the step repair using their panels tho.
I've been following this thread with interest because The jobs I've been doing on my mini have been pretty much in sync with what your doing here. (I'm still a novice, so my standard of work isn't anywhere near as good). I see you fitted your step before the work on the flitch tho. I hope this doesn't mean I've messed up doing my flitch first
#250 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 08 August 2014 - 07:41 AM
Fitting the flitch first before the step should make no difference. The step does not attach to it so should not be a problem.
#251 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 08 August 2014 - 08:14 PM
Right things never go to plan but such is life.
I fitted the jacking point then spent what felt like ages drilling 1/4" holes in the new outer sill. Sprayed a load of black paint in the inner sill cavity then on went the outer sill,
 i used some of Frosts Cold Front on the quarter panel section to keep distortion to a minimum.
#252 deepee71
deepee71
  • 101 posts
Posted 09 August 2014 - 07:02 PM
Nice tidy work as usual Neil..
Andy
#253 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 August 2014 - 05:41 PM
Quick couple hrs of messing around this afternoon. The step in the replacement inner sill does not match the original so a bit of cutting and shutting was required
so before
5803d7af-1bde-482f-909e-909cd08ce40d_zps
 and then after
There are a few more welds to dress down then that will be the end of the welding inside apart from the odd small repair to be done on the bulkhead.
And now i am more than a tad jealous of the skills Alan has. He is the chap who i buy my sheet steel off and also the fabricator of the new door steps. His very very very modified mini has nice shiny door skins which i though were ali but no hand made from stainless steel along with the bottoms of the doors. I will get some pics soon but he just keeps impressing me. Nice when you own your own fab shop.
#254 rally515
rally515
  • 3,848 posts
Posted 15 August 2014 - 07:23 PM
Ohh Stainless doorskins, is he starting making a Mini shell out of stainless ?  I'd luuuuvv one of those ;)
#255 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 August 2014 - 07:39 PM
Well its like the rest of the car, here's a little glimpse
