Wills Mini Special
320 replies to this topic
#196 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,031 posts
  • Name: Neil
Posted 23 June 2014 - 07:20 PM
Upwards and onwards with the inner sill, tacked in place
First lot of welding completed
Welds cleaned up
Then onto the inside joggled section
5515bb4d-b341-4b50-9a94-d7ecf56be35e_zps
44484ee6-a0c6-4dee-a883-f0e62027d972_zps
Rear heelboard bracket welded in
8f6b91ac-3c06-46f1-b9c8-b828f0810e7c_zps
and the end of the heelboard
tomorrow i'll have a go at the floor pan end to see what i can do with the rust tracks there.
#197 rally515
rally515
  • 3,848 posts
Posted 23 June 2014 - 07:23 PM
Beautiful work Sonikk, good idea on the joggling, bought myself one and can't wait to try and get results similar to yours, i did make a mess of Butt welding the inner sill on the mk2 project but alas, learing as I go.
Cheers,
Cliff
#198 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 23 June 2014 - 07:31 PM
Cheers,
Cliff
Butt welding done correctly is a better finish to be honest but joggling and welding both sides is a good strong joint though Cliff. It is a bit more work but as this is not going to be a bare floor car then its not going to be an issue.
#199 MarkGTT
MarkGTT
  • 528 posts
Posted 23 June 2014 - 07:56 PM
Nice tidy work, keep at it :)
#200 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 24 June 2014 - 07:18 PM
Ground all of the internal welds down today and fettled a few spots here and there so went onto the inner sill stiffener. This needed a few tweaks then it was welded in
Then it was onto the Companion bin and what a bugger that was. First thing at fault was the contour was not correct at the front causing this issue
Not good so after some tweaking, reshaping and cutting around i finally got it to look like this
100% better and this shows you how much of a curve the panel needs to be to fit on the B post
So from now on it will be Heritage only for me for this particular panel.
#201 Blitzman
Blitzman
  • 40 posts
Posted 24 June 2014 - 07:29 PM
Having read through the whole thread all i can say is awesome.
A masterclass.
After being away from the Mini scene for over 15yrs your work is a real inspiration. :-)
#202 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 24 June 2014 - 07:32 PM
A masterclass.
Thanks, its a bit of a ball breaker this car as it has been in an accident and poorly repaired which does not make my life any easier. Also the rust is everywhere from where its been stored in a damp container so that has not helped at all.
#203 Marco1972
Marco1972
  • 822 posts
Posted 24 June 2014 - 08:26 PM
Hi Neil great work as usual mate
Funny issue with the companion bin we had the same with the heritage one that we put in the lads car had a struggle fitting it in
Got there in the end tho :-)
#204 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 24 June 2014 - 09:13 PM
Well both of these were M Machine panels and were too big and not formed correctly. I think I will have to give them a bell to let them know what a pain they are to fit.
#205 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 02 July 2014 - 06:47 PM
Companion now fitted and pleased with it
Primered
And painted
Then i picked these puppies up as well. No more crap door steps for me
#206 henri1972
henri1972
  • 277 posts
Posted 02 July 2014 - 06:58 PM
wheres my steps :D :D
#207 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 02 July 2014 - 07:06 PM
Well the thing is i have two lots, now before anything happens i will trial these new ones on Wills mini. Then if they are good then we can see what happens with the others. If these are good then getting more will not be an issue. These are only the step section though so the curved ends will need to added but that is easy to do by just cutting these and adding the extra metal.
#208 deepee71
deepee71
  • 101 posts
Posted 02 July 2014 - 07:34 PM
Great work so far Neil, if these pressed door step panels do become available I would love to get hold of a couple. I have tried to use the ones from Magnum,.... :(
Andy
Edited by deepee71, 02 July 2014 - 07:36 PM.
#209 henri1972
henri1972
  • 277 posts
that is not a problem i am only teasing i am far from needing them but they look soooo good already
#210 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 08 July 2014 - 06:18 PM
Accident damage that has not been repaired properly and a poor Heritage quarter panels does not make for a happy Neil.
The quarter will not clamp up to the B post properly no matter what i do. I know have a some serious skin pinning going on to try and get round that little problem, plus some bending and reshaping. So at the moment there is no gap at all at the back of the door and this is with no shims. So once i have reskinned the door i will look at sectioning the front of the quarter panel if needed.
Skin pin central
And this is the poorly formed B post section of the quarter panel. This has now had some loving tender care with a hammer and block.
The new door step is good and will only require some minor fettling
