Wills Mini Special
320 replies to this topic
#181 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,034 posts
  • Name: Neil
Posted 23 May 2014 - 05:42 PM
The remaining flange welded in place ready for the arch
then it was onto the arch itself, all pinned together ready for plug welding
Then welded together
Back where it should be, just need to grind the welds flush
These will get  some treatment next fri.
#182 Broomer
Broomer
  • 1,771 posts
Posted 24 May 2014 - 08:09 PM
Really tidy job on the arches! want to do mine?
#183 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 24 May 2014 - 08:34 PM
Mmmm let me think about that for a sec............ nah thanks for the offer though :D  :D
#184 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 02 June 2014 - 07:18 PM
Quite a while spent grinding those plug welds down then it was into the rear valance close out.
So pinned everything in place
Plug weld holes drilled ready for weld
Welded in place
Ground flush and seam sealed
So hopefully after the dentist has rebuilt my smashed tooth tomorrow i can fit the valance.
#185 Marco1972
Marco1972
  • 822 posts
Posted 03 June 2014 - 07:57 AM
Cracking work as usual mate
Started this job on mine , what happened to the tooth ??
#186 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 03 June 2014 - 08:31 AM
Bit on something hard and felt something in my mouth and yep a bit of tooth. The following day another dirty great chunk went as well so not much holding the filling in. Need it done pronto as I'm off to Antigua fri.
#187 josh2490
josh2490
  • 10 posts
Posted 03 June 2014 - 10:38 AM
what a good thread for reference i shall be following this closely
#188 Marco1972
Marco1972
  • 822 posts
Posted 03 June 2014 - 03:24 PM
Hope it gets sorted before you go mate :-)
Think you deserve a holiday after all that graft
#189 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 03 June 2014 - 03:40 PM
Tooth has had some Dentist equivalent of Upol Fantastic filler as a temporary fix so fingers crossed that will do. If not I will be forced to drink even more beer and cocktails. Who am I kidding I will be doing that anyway.
#190 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 03 June 2014 - 07:46 PM
Rear valance on now
 Just got some final touches to do to the closeouts
#191 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 04 June 2014 - 08:00 PM
After a morning of titivating and sealing it was on to the inner sill.
Trimming to fit
pinned in place
and a small issue like the other side
#192 henri1972
henri1972
  • 277 posts
Posted 04 June 2014 - 08:08 PM
when is the next installment enjoying this
#193 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 04 June 2014 - 08:15 PM
Not for a couple of weeks now. I'm off to Antigua for a spot of drinking and eating this friday. Happy days.
#194 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 04 June 2014 - 08:30 PM
Looks like this is at the same place as mine. Had to put a small cut in my floor pan to line up as well.
#195 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 04 June 2014 - 08:32 PM
The problem i have have though is the rest of the floor pan although intact has a load of spider tracks in it. I may end up fabbing a new one.
