Wills Mini Special
320 replies to this topic
#136 SAL 821X
SAL 821X
  • 1,890 posts
Posted 21 March 2014 - 09:35 AM
Can you re use the putty Neil?
#137 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 21 March 2014 - 09:44 AM
can you reuse it or is it a one shot substance?
#138 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 21 March 2014 - 11:03 AM
Yes it's reusable and if it dries out too much you can add a drop of water. I will see how long a tub lasts.
#139 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 April 2014 - 03:21 PM
Managed to get a bit more done today but now have been called in for some overtime tonight and tomorrow so nowhere as much down as i hoped.
On with the drivers door
and the crusty bits
So a spot of fabrication was needed for the window frame especially the curved section
so after it was welded together i ended up with this repair piece
this was then used to supply the repair piece i needed for the front
The front got the same treatment but no pictures. Then the bottom section got a dose of angle grinder and ended up like this
#140 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 18 April 2014 - 10:03 PM
A quick hour and a bit worth of work on the door
new door skin with a splash of paint
9a27418c-e743-431e-9854-6223f3be4ff9_zps
front and rear flanges to do then its on with the skin.
#141 Marco1972
Marco1972
  • 822 posts
Posted 22 April 2014 - 04:12 PM
Looking good mate
Did you grind the edges of the door skin to remove it ? And is the skin and door bottom genuine or pattern ?
Got this to do on the lads doors he's got a magnum skin not looking forward to fitting that !!
#142 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 April 2014 - 06:47 PM
Yep ground the edges of the skin then popped the spot welds that attached the skin to the frame.
The repair section on the bottom is pattern but the skin is Heritage. To be honest i have not many issues with the doors i reskin for sale and they are all Magnum skins.
#143 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 28 April 2014 - 07:01 PM
Some more work on the door and skin today
New flanges all welded in place
Apart from the flanges the door frame is in very good condition, only one small section of hidden rust but that got the treatment
50c135cb-ddcf-4c7f-89b3-2a36412066c7_zps
cb833f60-a1cb-4a56-b46a-7408031cdd6f_zps
And the door skinned and fitted in place
The gaps at the back of the door are very good apart from one small area but that will be sorted tomorrow
The bottom is a different story and one for another day. I'm waiting on my new door steps that i have got an order in for being made to see how well they come out. They have to be better than the horrid Magnum step that i fitted and modified. If not then i will add some metal to the bottom of the door as well.
#144 henri1972
henri1972
  • 277 posts
Posted 28 April 2014 - 07:22 PM
as always great work keeping an eye on this one
#145 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 29 April 2014 - 06:36 PM
Finished the rear section of the skin and pleased with it
Then it was onto the rear l/h quarter
This was replaced by a bodyshop at some point and lets say nearly 50% of the spot welds had not taken at all. Oh and the rust on the arch lip will need to be sorted
And this is my mates roof decal on his mini
Also said bodyshop applied filler over paint and guess what it peeled off
#146 henri1972
henri1972
  • 277 posts
Posted 29 April 2014 - 07:09 PM
love that decal turning green with envy
#147 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 29 April 2014 - 07:11 PM
Its good i have to admit, not what i would want on my car but it suits his.
#148 rally515
rally515
  • 3,848 posts
Posted 29 April 2014 - 08:55 PM
Nice work Sonik, is that 1.8mm Gas welding filler wre you're using to build the lip up ?
#149 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 30 April 2014 - 05:40 AM
Nope it's 3.4mm welding rod.
#150 rally515
rally515
  • 3,848 posts
Posted 30 April 2014 - 07:17 AM
Ahh righty O, quite thick rod I must say!
