Wills Mini Special
320 replies to this topic
#1 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 22 August 2013 - 08:35 PM
Being a glutton for punishment and also wanting to make a few quid to spend on Paddy i have taken on a 79 Special which is owned by Will one of the lads from our Heathrow hangar.
He got delivered to the workshop at the beginning of the week by one of his mates. Overall condition is not that good and by the looks of it nearly every external panel needs to be replaced along with both outer sills and i think some of the inners. The floors were badly pushed in but a large block of wood sorted those out.
The scuttle looked good funnily enough so less work to do there then????? NOT it was rusty underneath
The r/h rear arch is toast though
Very poor picture but the r/h heelboard end is not looking good, its bulging out
The l/h rear quarter had been replaced in the past due to a shunt but not done well as they forgot to sort this out
and all of the spot welds had holes through them, very strange
L/h inner sill in the companion bin is crusty
L/h door step is gone as well
and some pony repairs to the lower flitches both sides
#2 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 August 2013 - 08:47 PM
Day two.
Time for some panel removal so off with his front end
and the scuttle taken off to see all of this
Not bad for the original scuttle i have to say.
Then onto the bulkhead especially under the hinge mounts
The flitch bottoms under the scab patches
Now onto the bulkhead hinge mounts
Old metal cut out and new metal tacked in place
Metal in and bracket pinned in place waiting to be plug welded
Day three
L/h side welded in
Both mounts are in but no pictures
then onto the l/h shock mount. It looked really good so i thought a clean up would be all it needed but no the meatl was still pitted
cutout and behind was not that bad
just surface rust and cleaned up very nicely and welded up well
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 August 2013 - 08:48 PM
This is so cool! I used to have one of these. Mine was a pale blue one with black vinyl roof. I loved that thing!!
Ben
#4 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 August 2013 - 08:51 PM
The car has been in his family from new i believe and has been stored in a shipping container for sometime which is a shame.
The front end had been replaced in the past which he thought was strange but considering the wings were basically tack welded on and then the seams filled with filler speaks highly of whoever did the job. It was very very easy to remove.
#5 Mini-Mad-Craig
Posted 22 August 2013 - 09:00 PM
Solid little thing! nice work so far mate. Looking very nice. Will be watching closely
#6 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 09 September 2013 - 03:47 PM
Little bit more progress today.
First thing was to knock up some bracing for when / if i have to replace the inner sills.
Started with a cross brace over the cross member.
then the support pads for the crossmember
Welded
Then the front and rear cross braces
Onto the car and the back is crusty
Its going to need a full width hinge panel and also a boot repair panel to go along with the others already on order.
Next week the outer sills are coming off to see whats hiding behind them.
Cutting along.
#7 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 09 September 2013 - 04:23 PM
This will be a good one. Best of luck.  :-)
#8 minimikej
minimikej
  • 347 posts
Posted 09 September 2013 - 07:39 PM
There's really not much wrong with this one! And Special Roses were notoriously crusty! Love the 1100 Specials.
#9 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 13 September 2013 - 12:14 PM
Good swift project. Nice example of how to repair typical mini corrosion.
#10 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 16 September 2013 - 06:32 PM
Cheers Jagman not so sure about swift but it will be a lot faster than Project Erm, anyway upwards and onwards.
Got the rear valance close outs off and most of the rust in those areas, the outer section of the inner arch has to go this side as well.
then it was off with the l/h sill which was worse than it looked but we did get a free pencil
and surprise surprise the inner sill is shot so will be needing a M Machine inner sill down to the first flute on the floor. And a new jacking point as well. Going to trim off the rear slinging point to see how bad the rear subbie attachment bracket is.
And a couple of measurements to make sure i can refit the fuel tank strap mounting bracket.
#11 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 September 2013 - 06:50 PM
The r/h side got its just deserts today and was pretty much a carbon copy of the other sides sills
The doorstep looked good but underneath was a different story
so thats both sides to do
then it was time to do some localized rust and damage repairs on the r/h inner wing, this being the front lower section where the front panels ears fit
and this rust just behind the cutout for the front subbie
and cut out
and finished
#12 Mini-Mad-Craig
Posted 17 September 2013 - 07:35 PM
Coming on well matey! do you have the interior? Ie dash and center console?
#13 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 September 2013 - 07:41 PM
I think Will has Craig as they stripped the car before sending it to me.
#14 Mini-Mad-Craig
Posted 17 September 2013 - 07:42 PM
Oh fair enough, otherwise I may be able to help with a center console from a friend in Holland :thumbsup:
#15 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 September 2013 - 07:50 PM
I can ask him if needs another.
