Alloy heads have better heat dissipation, solving the classical issue of hot-spots of A-series engines.
As a result, the are also supposed to be less inclined to "knock", allowing slightly higher compressions.
As for bimetallic corrosion between a cast iron bottom end and an aluminum alloy head, it should be very very limited for 2 reasons:
- cast iron and aluminum alloys are quite similar in terms of electric potential and are both on the "negative" side
- the cooling liquid is supposed to be a very poor electrolyte
Bimetallic corrosion should be much worse between cast iron and titanium, copper or bronze and we can see these metals in many engines parts, including copper gaskets, in direct contact with cast iron surfaces.
You can have a look at page 3 of the following document to see a scale of electric potential of various metals:
http://www.npl.co.uk...71105114556.pdf
I'm precisely in the process of choosing a 7 port head. I'm inclined to take a MED 7 Port Trackday head. it costs 1725GBP inc VAT, is made from the same base as Webcon's, but is fully ported by MED and fitted with decent valves (37/31 instead of 33/29) and springs.
Specialist Components head was another option seriously considered, is very close in price (1650 inc VAT) but needs specific throttle bodies (36mm with a bespoke spacing and no injector plug, since injectors are directly plugged into the head) bringing the total cost higher (300gbp more for a SC "kit" excluding ECU).
Diogo
