Intermittent Fan Problems !
Posted 18 August 2013 - 06:58 PM
Posted 18 August 2013 - 07:18 PM
you need this
and this
http://www.minispare...90.aspx|Back to
Posted 18 August 2013 - 07:28 PM
Posted 18 August 2013 - 07:47 PM
i changed mine as par of the upgrade, might as well for a few quid
and your welcome
Posted 19 August 2013 - 07:39 PM
Posted 19 August 2013 - 07:47 PM
Posted 30 August 2013 - 10:36 AM
Just bumping this back because I can't get the links to work. Am after a new temperature sensor too but also....my intermittent wiper isn't working. Park, sweep fast and slow all work just not the first position for timed sweeps. Am led to believe it is the relay under the steering column/dash but I don't know what it is and can't seem to pin down what I need.
Could someone link both the sensor and the relay?
Many thanks.
Darryl.
Posted 30 August 2013 - 01:48 PM
You can see the brown temp sensor on the same page
Posted 30 August 2013 - 02:47 PM
..ahhh yes...I was at work sneaking on and I think I was blocked. Ordered those. Thank you so much.....now...intermittent wiper relay/sender unit thingy anyone?
Pleeaaase?
Posted 30 August 2013 - 02:53 PM
At that price I might just do without it, after all earlier minis didn't have that feature.
Posted 30 August 2013 - 03:27 PM
If yours is an MPi then you actually need this for the wipers:
http://www.minispare...h/classic/wiper relay.aspx|Back to search
The other one is a conversion for early cars
Terry
Posted 30 August 2013 - 03:50 PM
Other cars used them including Land Rover. Brit car have some
http://www.brit-car....wiper_disco__la
Posted 30 August 2013 - 06:30 PM
Can I just clarify something...mini spares haven't had the correct part for ages but what you're saying Mr A-Cell is the Land Rover one is correct to fit as a replacement?
Mine is actually a '97 mpi...
...there is 40 quid riding on this...
Edited by Laughing Gravy, 30 August 2013 - 06:33 PM.
Posted 30 August 2013 - 07:26 PM
id say try the wiper park swirch 1st, as this also could be cause of the fault
Posted 30 August 2013 - 09:45 PM
..everything else has been replaced and all works well...it just doesn't 'do' intermittant!
