I am attempting to repair the flange on the front panel of my car. The panel itself is in excellent shape aside from a dangerously thin flange that needs to be reinforced prior to having the wing welded on.
I was hoping not to replace the corner of the front panel just because of this flange, and was thinking about doing the following:
Creating a reinforcement patch in the same shape of the flange and spot welding it on - that way when the wing comes down on it, it should be stronger. Is this acceptable? What is your take on the proper way to repair - not replace - this flange if at all possible?
I have included photos of the damaged flange as well as a shot of the reinforcement piece I created resting on it... Also, the car is currently upside down on a rotisserie (hence the awkward vantage point.)
