Intermotor Electrical Part Numbers
No replies to this topic
#1 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 August 2013 - 02:34 PM
Intermotor Part Number Of Electrical Parts
Vehicle Details
Manufacturer AUSTIN Model Mini Stroke cc 998 Kilowatts 28 Fuel Type Petrol Number Of Cylinders 4 Engine Type OHV Engine Code 99H From 10-1967 Till 09-1984
Part No. Type Comments Fitment Universal Part No.       51590 Brake light Switch Pedal operated           33440 Condenser Ducellier           33670 Condenser 78-80 Ducellier           33710 Condenser ->1974 Lucas           33710 Condenser Lucas           33720 Condenser 1974-> Lucas           33720 Condenser Lucas           22390 Contact Set Ducellier           22560 Contact Set ->74 Lucas           22560 Contact Set Lucas ->74           22560 Contact Set Lucas           22560 Contact Set ->75 Lucas           22580 Contact Set 1974-> Lucas           22580 Contact Set Lucas           23451 Contact Set Lucas 80->           44140 Distributor Cap Lucas ->74           44280 Distributor Cap Ducellier           44720 Distributor Cap Lucas ->69 Side entry           44750 Distributor Cap Lucas           44750 Distributor Cap Lucas 74->
Part No. Type Comments Fitment Universal Part No.       58840 Flasher Unit             58850 Flasher Unit             58940 Flasher Unit For Trailer           11040 Ignition Coil ->1980 12V Push in HT connection           11070 Ignition Coil Ducellier / Lucas           11105 Ignition Coil             11110 Ignition Coil             50500 Oil Pressure Switch             51000 Oil Pressure Switch City/E/HL/HLE/Mayfair           54880 Reversing Light Switch City/E/HL/HLE/Mayfair           47300 Rotor Arm Ducellier           47300s Rotor Arm Ducellier           47510 Rotor Arm Lucas           47510 Rotor Arm Lucas ->74           47540 Rotor Arm Lucas           47540 Rotor Arm Lucas 74->           68000 Starter Solenoid ->1969           68010 Starter Solenoid             52710 Temperature Transmitter             75000 Thermostat
Manufacturer AUSTIN Model Mini Stroke cc 1098 Kilowatts 33 Fuel Type Petrol Number Of Cylinders 4 Engine Type OHV Engine Code 10H From 09-1969 Till 08-1981
Parts For Selected Vehicle
Part No. Type Comments Fitment Universal Part No.       33670 Condenser 78-80 Ducellier           33720 Condenser Lucas           22390 Contact Set 78-80 Ducellier           22580 Contact Set Lucas           11040 Ignition Coil 12V Push in HT connection           11105 Ignition Coil             73792 Ignition Lead Set             75233 Thermostat
Manufacturer AUSTIN Model Mini Stroke cc 1275 Kilowatts 39 Fuel Type Petrol Number Of Cylinders 4 Engine Type OHV Engine Code 12H From 09-1969 Till 09-1980
Part No. Type Comments Fitment Universal Part No.       33710 Condenser ->1974 Lucas           33720 Condenser 74-> Lucas           22560 Contact Set ->73 Lucas           22580 Contact Set 74-> Lucas           44140 Distributor Cap Lucas ->74           44750 Distributor Cap 74-> Lucas           58840 Flasher Unit             58850 Flasher Unit             58940 Flasher Unit For Trailer           11040 Ignition Coil 12V Push in HT connection           11105 Ignition Coil             73792 Ignition Lead Set             50500 Oil Pressure Switch             54880 Reversing Light Switch             47510 Rotor Arm ->74 Lucas           47540 Rotor Arm 74-> Lucas           52760 Temperature Transmitter             75000 Thermostat
Edited by KernowCooper, 15 August 2013 - 02:50 PM.
