Fia Mk1 Cooper S "replica"
150 replies to this topic
#1 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 01:33 PM
Hello everybody!
I'm Albert from Barcelona (Spain).
Since the first time I saw FIA Pre-66 Minis I wanted one. However it's really expensive to build one so I decided to build a replica with my 1974 Mini. Hope you like it!
At Facebook I have many more photos. If you want to see them, here is the link of the album: LINK
The specs:
Engine:
A+ 1330cc. 12G940 modified head. EN40B crankshaft. Kent MD276 camshaft, duplex timing gear. MED Engineering 1,5:1 rollers. Twin SU HS4 with MED Engineering ITG filter and stub stacks. Facet fuel pump. 123 Ignition distributor. Maniflow LCB Stage II exhaust manifold. Mini World Center stainless steel exhaust. Aldon Flamethrower coil. NGK spark plugs. Mocal oil cooler.
Gearbox:
4 speed SCCR. X-Pin diff. FD 3,44:1 (18/62). AP clutch. KAD Mini Moke quickshift.
Brakes:
Front: KAD 4 pot calipers. KAD 7,75" grooved and vented discs. Minispares carbometallic pads. Goodridge hoses.
Rear: Vented drums.
AP "Yellow tag" master cylinder. Servo. Motul RBF600 Dot 4.
Suspension:
Front: Öhlins shocks. Minispares competition springs. Hi-Los. Adjustable lower arms and tie-rods.
Rear: Öhlins shocks. KAD anti-roll bar. Minispares competition springs. Hi-Los. Adjustable geometry kit.
Wheels:
Minispares 4,75x10" Rose Petals. Yokohama A032R.
Interior:
Sparco Sprint V seats. Sparco R323 steering wheel. OMP 3" 4 point harnesses. 0-200 km/h Speedo. Tachometer Stack. Stack gauges. "Works" custom dash. OMP 6 point rollcage. FIA Rain light.
Body:
Spanish MK3 bodyshell. P4P MK1 polycarbonate window kit. Surf Blue (BU35) y Old English White (WT3).
Now, I'll start with the photos  :proud:
Pd. sorry for my english  :shy:
17 kilos of Dynamat to the rubbish. I want my Mini as light as possible.
First tests...
Continue...
Edited by farres_jr, 15 August 2013 - 01:58 PM.
#2 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 01:38 PM
More images
#3 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 01:46 PM
Some of the components I bought to complete my project  :proud:
#4 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 01:56 PM
And some more!
Cleaning subframes and preparing to powdercoat them.
Welding some steel to fit seat frames
Seats fit well
As Minisport Works dash don't fit good with front rollcage, I designed new ones for my car. I also designed the rain light bracket.
Testing dash and rain light bracket
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
very nice mate, only thing I'd have done different is use smiths period gauges, but cracking job well done and yes the price of the real thing is out of reach of most, unless your James Martin the TV Chef, he has about £100k's worth of minis and counting
#6 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 15 August 2013 - 02:00 PM
Looks good mate, keep going.
#7 jaydee
jaydee
  • 8,565 posts
Posted 15 August 2013 - 02:01 PM
Meh these stack gauges are pretty expensive youre not on low budget mode  :gimme:
Good luck with the project!
#8 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 02:04 PM
Many thanks!
I saw Stack gauges in a FIA Mini in Barcelona Historic Festival and I loved them  :lol:
If one day I win the lottery I'll build an authentic FIA Mini and race it  :shifty:
WOW! Mad mk1 replying my post!  :proud:
I've been following your project since I bought my Mini. In fact, the first time I saw Stack gauges in a Mini was in you car.
Thanks!!!
Yes, they are expensive but they look awesome and work really well.
Many thanks mate!
#9 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 02:11 PM
At last, some Surf Blue paint!
Ready to go to the paint workshop  :lol:
Working on the dash
I decided to buy a Cartek rain light switch for my LED rain light. Expensive but really easy to install. You only have to connect 3 wires
#10 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 02:20 PM
In the paint workshop
Mini at home again
Powdercoated suspension bracket
And testing Öhlins
#11 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 02:27 PM
A few bits from KAD arrived  :lol:
The dash is finished
And starting with the custom wiring loom.
Working on front subframe
And rear subframe
#12 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 15 August 2013 - 02:32 PM
Very, very nice!! ;D
#13 farres_jr
farres_jr
  • 105 posts
Posted 15 August 2013 - 02:41 PM
Rear subframe installed
And front one too
Testing driver's position
The new gearbox internals
598693_10200242701097718_1141184767_n.jp
After a year, Mini is on the ground again
549412_10200309900217654_1774206041_n.jp
Ready to fit the tow strap
282712_10200321401665183_1862083684_n.jp
482613_10200441973839412_1094495601_n.jp
The new speedo
And some engine updates
Painted engine at home again!
923127_10200888222195342_1684777057_n.jp
#14 minispaniard
minispaniard
  • 899 posts
  • Local Club: Essex Mini Club, CMC.
Posted 15 August 2013 - 02:45 PM
anyone said Spanish recession?
tremendo!! ;D
#15 Mini-Mad-Craig
Posted 15 August 2013 - 02:51 PM
With the beautiful attention to detail put into this build it's a shame you couldn't source a genuine Mk1 shell, lovely work.
