1.8 Vtec Mini - For Sale
6 replies to this topic
#1 Boots
Boots
  • 151 posts
  • Local Club: North Devon Mini Club
Posted 14 August 2013 - 07:04 PM
The time has come for me to reluctantly sell my 1990 Mini. Being a self-employed personal trainer working silly hours, has left me with very little time to continue the potentially small amount of work needed to have the car back on the road/track.
It started its life as a blue 998cc Rover mini, It had seen much better days. The car was completely stripped down & shot blasted. Any damaged/rotten panels were replaced with heritage panels and certain areas received extra attention with a focus on strengthening or accommodating engines or Fuel tanks. The car was sprayed Ferrari Gialofly Yellow, with a Black roof. I choose to attempt a vtec conversion, which originally started with a B16A2 but later replaced with a B18C4, due to its LSD gearbox and the fact I had the complete donor car making the conversion a lot easier. If you want more info on the build here is a link to the build thread - http://www.16vminicl...&highlight=wasp
All consumables, seals, gaskets & bearings have been replaced with new items.
Engine + Subframe Etc
•    Honda B18C4 all internals are stock.
•    Standard Honda engine management system
•    Skunk 2 Inlet Manifold
•    Billet Alloy 75A Track engine mounts from Innovative Mounts
•    Watson Front Vtec Conversion Subframe
•    Watson Honda to Metro drive shafts + other conversion parts
Suspension + Brakes, Wheels Etc
•    Gaz center mounted Coil Overs, With aftermarket D Faulkner Springs –Front 400x1.9 Rear 200x1.9
•    MGF Brake Callipers – Powder Coated Yellow
•    Vented MGF Discs
•    Mini Superfin rear drums
•    Watson Rear Wheel spacers
•    Reconditioned Radius Arms
•    TDK Rear Beam – Fully Adjustable
•    Wilwood 0.625 Brake master cylinder
•    AP Racing 14mm Clutch Master Cylinder
•    Compomotive ML  13”x7” on Contisport 175/50 Tyres
Shell + Bodywork etc
•    Bumper Mounting strips removed
•    Removable metal front end
•    Scuttle blank holes welded
•    Bulk head blank holes welded, also modified to accommodate Inlet manifold,
•    Front Coil over mounting points strengthened
•    Front Subframe floor mounting points strengthened
•    Rear Seat Lip removed
•    Boot floor extensively modified – the floor sits higher to cater for alloy fuel tank and Exhaust backbox, giving good clearance from the road, the boot is still just as usable as a standard boot, in fact possibly more so.
•    Rear wheel  arches are extensively modified to accommodate 13” wheels and Centre mounted coil overs
•    Parcel shelf is removed and replaced with alloy version.
•    Front end has swaged holes for extra cooling to the radiator.
•    Heel board stregthend.
Extras
•    Safety Devices Roll Cage – Front, Rear and Side door bars
•    Cobra Monaco Seats + Harness’s
•    Power Vamp Racing Battery – PVR25 + Alloy mounting bracket
•    Custom Internal Gear linkage + Alloy Gear Knob
•    Curley Fiberglass Miglia Arches
•    Mountney Steering Wheel
•    Alloy Racing Fabrication Fuel Tank with internal swirl pot, sender & tank straps
•    Honda wiring loom, shortened & lightened by Motatec
There are lots of other little bits which aren’t worth mentioning in detail, like old parts, extra seals, wing mirrors, nuts & bolts, Ariel etc. But what you see pictured is what you will receive in the sale.
£5000
If you have any questions please contact me via Email - [email protected] or via the forum, I'm more than happy to answer what i can
Steve
ps, I would like to add I almost sold the car twice over on the 16vminiforum, but the potential buyers messed me around, so please if you are genuinly intersted in buying then please make contact :)
#2 deanymini
deanymini
  • 771 posts
Posted 16 August 2013 - 01:39 PM
Worth every penny if you ask me. If I hadn't have bought mine last year then I'd have snapped this up. You even get the chance to add your own little touches like carpets, arches, dash, etc. Good luck with the sale.
#3 Sausage
Sausage
    Starting My Mini Up
  • 1 posts
Posted 16 August 2013 - 08:24 PM
What gearing is this running? What revs @ 70 in 5th?
#4 sambuckley
sambuckley
    Starting My Mini Up
  • 2 posts
Posted 10 September 2013 - 10:37 PM
pm'ed
#5 Dolly 89
Dolly 89
    Previously known as suzzy 273
  • 1,366 posts
  • Local Club: Humberside moc
Posted 20 September 2013 - 06:10 PM
Awesome car, wish I had the money :(
#6 Petro1head
Petro1head
  • 168 posts
  • Local Club: Cooper Register north est
Posted 30 September 2013 - 02:11 PM
Hi
I looked at your build thread and have a couple of questions if you don't mind
Was the original front end fibreglass and then you replaced it with steel?
Why did you change the rear tank setup?
#7 samsfern
samsfern
  • 5,243 posts
Posted 30 September 2013 - 02:55 PM
Part ex for a yellow 2007 ford fiesta Zetec s 30th anniversary?
    Bing (2)
