HS4 Lift pin
Posted 10 May 2006 - 03:29 PM
Just need a pic showing me where it is please
Posted 10 May 2006 - 03:56 PM
With the engine running (full warmed up) lift the piston-lifting pin till it hits the piston and then a further 1 mm on the side of the carb and listen to what happens,
If it cuts out the mixture is too lean, if the idle increases the mix is too rich and if nothing happens the mixture is about right.
The Haynes manual goes into much more detail, Pages 4A .15 and 16 fuel systems.
Posted 10 May 2006 - 04:00 PM
Posted 10 May 2006 - 04:04 PM
what is it for??
So you can set up the running of the carb at home.
Posted 10 May 2006 - 04:26 PM
Posted 10 May 2006 - 04:32 PM
Posted 10 May 2006 - 05:27 PM
This is what mine looks like
Is this a HS4? ANd if so wheres my lift pin?
Heres another pic
Posted 10 May 2006 - 06:00 PM
Posted 10 May 2006 - 06:07 PM
Not all HS carbs have a piston lifting pin, and no metric HIF carbs ever had them (imperial HIFs did). I think it was deleted around the time that Waxstat jets were introduced but I'm not sure. That would make some sense though as the Waxsatat makes it a much less useful tuning tool. I've always found the plateau method of tuning more effective.
Oh ok, So whats the plateau technique? How do i do it please?
Posted 10 May 2006 - 06:34 PM
As you turn the jet into the carb you will notice the revs gradually rise and then start to fall back again as you go further. Between the rising and falling there is a plateau where the revs remain the same whatever the mixture which lasts for 6 flats of the jet. The correct jet position is two flats back from the edge of the plateau. You need a good, stabilised tacho. The car one isn't really good enough and is in quite the wrong place for this, but you can get tuning multimeters with tacho's built in which make this easy. You can't just do this on its own as you need to tune the whole thing at once but as I said, there's more detail in the manual.
