Specialist Components Mpi Throttle Body Kit
68 replies to this topic
#46 SComponents
SComponents
    Just On Tickover
  • 9 posts
Posted 11 March 2015 - 11:23 AM
Hi All
The SC MPI management kit can work with the original Rover Alarm/Immobiliser left in place and functioning. We have developed this kit to be as simple to install as we can - our wiring loom plugs in with OE connectors. Obviously if you wish to remove the alarm for any reason our ECU will function without it too.
With regards to our current design stainless LCB's, we fit 2 lambda bosses so that the Rover sensor can be fitted to the upper one without modification. The best place for sampling is from the lower boss in the y piece, but we have found that for MOT tests etc the upper mount is satisfactory.
jamesmpi - I'm surprised to hear about the fitting issues - we have sold literally hundreds of these items. It sounds like you had an earlier item with just the 1 lambda boss, so its a little late to help now, but let us know if you ever have issues again.
SC
Edited by SComponents, 12 March 2015 - 03:01 PM.
#47 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 30 March 2015 - 05:42 PM
Thanks for replying SC I have been extremely busy with work, started to look at my mini again and hopefully if all goes right I shall have your kit this year
#48 Midas Mk1
Midas Mk1
  • 5,768 posts
  • Local Club: S.U.N.M.C
Posted 30 March 2015 - 05:45 PM
I've got  abit of a weird scenario, wanting the 5port kit for my MPi, but i'm going to beusing a pre mpi 1380 block, but with an existing MPi loom, is there any way around this so that I can use the plug / play connectors, but with the carb conversions components? (trigger wheel etc)
Edited by Midas Mk1, 30 March 2015 - 05:46 PM.
#49 SComponents
SComponents
    Just On Tickover
  • 9 posts
Posted 31 March 2015 - 10:16 AM
Hi Midas Mk1. The loom we offer can only plug into an MPI system - however you could use the flywheel with crank trigger from the MPI. You will need the transfer housing for the sensor location, and to use an MPI coil pack. We don't use the cam sensor so this doesn't matter.
SC
#50 tmsmini
tmsmini
  • 723 posts
  • Local Club: MOASF
Posted 01 April 2015 - 06:43 PM
With my SC MPi kit when attempting to use the stock MPi throttle cable with the SC throttle body, the cable is almost pointing straight up as it comes away from the throttle body. This causes a severe angle to the cable when the bonnet is closed. Perhaps this is only an issue with left hand drive cars. Any one else observed this?
Terry
#51 brivinci
brivinci
  • 1,152 posts
Posted 01 April 2015 - 09:30 PM
I bet being LHD is not helping as it is the same side as the butterfly, correct?
Actually, how does the LHD stock setup works??? My SPi is RHD and the throttle comes from the right and goes across the back of the rocker where it pulls the throttle. The throttle goes from left to right. How does it work on your car? I know the brake is on the right side of the engine bay and there is a bar across the car to operate it correct?
#52 Midas Mk1
Midas Mk1
  • 5,768 posts
Posted 01 April 2015 - 09:35 PM
SC
That is perfect!  Thanks! Will be ordering an MPi kit in the next few weeks once I'm unto date with my Uni work :thumbsup:
#53 tmsmini
tmsmini
  • 723 posts
  • Local Club: MOASF
Posted 02 April 2015 - 07:52 PM
I don't have a photo showing the difference at this time, but here is an image from the manual. The MPi comes off in a horizontal fashion and I do not believe there is any change for RHD/LHD.
#54 jamesmpi
jamesmpi
  • 1,940 posts
Posted 04 April 2015 - 05:40 PM
SC
Hello
Upon reflection I think my comments were a little unfair on the basis that I didn't contact you about the problem. At the time (and I'm talking 6 or so years ago) I was desperate to get the engine back in so needed to find a fix rather than wait to send it back. I still have the manifold if you wish to inspect it....
#55 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 07 April 2015 - 06:44 AM
Hey I've had my kit on a few years now but does anybody know if you need the original fusebox with the 4 big 30 amp fuses? I've mine connected but just wondering do you run without it
#56 TiMtImInYtImTiM
TiMtImInYtImTiM
  • 75 posts
Posted 23 August 2016 - 11:28 AM
Sorry havnt been on in a few days, well i got to the stage where i was running a full stage 3 set up on the standard rover injection system and it didnt run great and should have had better performance so i went for the sc kit and it has totally transformed it! More power more torque smoother running! Its so easy put in no modifying looms or anything like that but yes sc provide a basic map but mine didnt run with thier base map but once i took it to my tuner he had it running sweet in a matter of hours!
My set up
Stage 3 head
1.5 roller rockers
Sw5 cam
Lightened duplex
Straight cut drops
Rebuilt box
3.4 ratio
4 pin diff
This is very similar set up to me. I have an ITG Filter as well. You refer to this as the SC Throttle body kit but then mention tuning on a rolling road. Does the Throttle body kit contain a new ECU?
What sort of power are you getting from the engine now?
#57 Steve220
Steve220
  • 5,016 posts
  • Local Club: BMC
Posted 23 August 2016 - 11:46 AM
Yes, it comes with the Typhoon ecu which is programmable. I've the same kit waiting to go on my turbo MPi engine.
#58 cian
cian
  • 869 posts
Posted 23 August 2016 - 05:35 PM
oh a fuel injected turbo! Sounds very trick!
Edited by cian, 23 August 2016 - 05:39 PM.
#59 cian
cian
  • 869 posts
Posted 23 August 2016 - 05:42 PM
My set up
Stage 3 head
1.5 roller rockers
Sw5 cam
Lightened duplex
Straight cut drops
Rebuilt box
3.4 ratio
4 pin diff
I have since rebuilt the engine to 1330 I changed to an sw8 cam full straight cut gearbox quaife diff a Med wedged crank and lightened flywheel i got 95bhp and 88 ftp but since that rebuild I've put a race 3 into 1 manifold and a maniflow rcm race exhaust so it might be more probably not though lol
#60 cartneil
cartneil
  • 46 posts
Posted 03 September 2016 - 10:09 PM
HI Cian,
Bit late to this thread (!), but what kind of 0-60 times do you reckon your set up would achieve? How does it feel off the traffic lights? I am rebuilding my mini and going for a very similar set up to yours, so was hoping it had a good bit of go acceleration wise! Also, what final drive diff ratio did you have?
