Smiths Tachometer Rvi-Rvc
6 replies to this topic
#1 TehMarchant
TehMarchant
  • 628 posts
Posted 05 August 2013 - 07:22 PM
Okay so I have a positive earth RVI tacho that I would like to have converted to RVC, I have been quoted £75 +£12 P&P + VAT Which I think is a little steep. Anyone able to go cheaper or know somewhere that will.
I don't want the gauge refurbished only the board changed and calibrated.
Cheers.
Edited by TehMarchant, 05 August 2013 - 07:23 PM.
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 05 August 2013 - 07:27 PM
You used to be able to get the boards for about £30 and you can do it yourself if you are handy with a soldering iron.
#3 TehMarchant
TehMarchant
  • 628 posts
Posted 05 August 2013 - 07:32 PM
I have found them for £40 but how likely is it that the board will work with my specific tacho? I have a 2423/01 and I think they're kinda rare as I haven't seen much on them.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 05 August 2013 - 07:35 PM
If the board is £40 then £75 seems a good price to have someone do it for you. I doubt anyone is going to do it for much less unless you get lucky and find someone with an old board in stock.
#5 TehMarchant
TehMarchant
  • 628 posts
Posted 05 August 2013 - 07:38 PM
But I really can think of better things I could spend £75 on as it is a lot of money, I have though about doing something like this http://www.dinoplex.org/tachoconversion/  What is the likely hood that if I walked into a electrical store with that list they would be able to find everything on the list?
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 05 August 2013 - 07:41 PM
A bit of a long shot, but could you get a cheap Tim tachometer or similar and swap the guts over. Only issue might be calibration so you would need one with a similar scale. I converted an old smiths clock like that, but obviously a time clock doesn't need calibrating, one revolution is always 12 hours! Or just buy a cheap tachometer and fit that.......
#7 TehMarchant
TehMarchant
  • 628 posts
Posted 05 August 2013 - 07:45 PM
I have seen something about doing that and I think if I could get a gauge at the right price I would give it a go, the only problem is that I don't want to buy a gauge that doesn't work, I don't like buying second hand electrical as I know ho stupid people can be. :proud:
Good advice and I will give that a go, I never thought about using a cheaper tim gauge I was looking a smiths and they're a little more costly. I will see what I can get and hope that I will able to get the beautiful gauge up and running.
