Hi All,
I've just purchased a gorgeous 1978 Mini 1000 and start my first of many repairs...the front left indicator light.
When I started the project, the side and rear indicator would work but blink very rapidly. The hazards also worked.
Many hours later I'm farther from a fix than when I started.
The main problem that I could determine was that the ground connection to the bulb holder was broken so I soldered that back on.
After playing with bulbs and accidentally trying a few dead bulbs it looked like it was going to work. Without everything put back together, the bulb was lighting just fine.
Fast forward and everything is back on. I go to turn on the indicators and the entire left side is dim. I can hear the ticking but the bulbs are barely lighting. The right side works fine.
Now, when I press the hazard switch it buzzes a bit and then the inline fuse (number 67 I think) blows.
I've hunted around for a problem quite a bit so maybe all my probing caused a short? I'm not quite sure what could have caused that.
I'm not quite sure what I can do to help check the problem but I'm up for trying whatever. Here is what I have tried:
- Taking the bulb out of the left socket: No change, the left side still blinks dim and not any faster. This (to me) says that I messed something else up while under the hood or is the socket bad?
- Replacing the inline fuse: At first it blew immediately again when I put it in but I put another in and it is fine. I think if I hold down the hazard switch it will blow again but the buzzing of the switch kind of worries me.
- Checking the main fuse box. Low resistance across all leads.
- Checking the brake and reverse lights as I understand there are on the same circuit: both work.
Thanks for any guidance, I'm looking forward to conquering my first Mini repair job.
