if only there was some way of connecting computers together, maybe like a 'web' and then if you could search it wouldn't that be fantastic!!
http://www.roadtyres...60-65-315-S.asp
Posted 03 August 2013 - 12:47 AM
Posted 03 August 2013 - 06:17 AM
Posted 05 August 2013 - 01:53 PM
I've actually got a set of Metro GTa alloys you could have (yes Austin ones and not Rover ones). Tread is legal on the tyres I think but I'd replace them as a matter of course. They are 13" rims though.
Iain
Posted 17 December 2013 - 06:04 PM
Sorry to bring up an old thread guys!
I have been doing a bit of reading, as I have finally gotten round to fitting 12 inch mini wheels on the front of the metro.
Now it was a real squeeze to fit these on, I knew it would be tight but Im a bit worried about the stress on the studs and nuts..
I dont want my gf going along for a wheel to sheer the bolts on her way to uni; should I just be on the look out for some metro steels?
Thanks guys!
Posted 17 December 2013 - 06:10 PM
I have good metro metric tyres.
Posted 17 December 2013 - 06:28 PM
Thankyou for the offer but I'd rather get some imperial wheels, however I might give you a PM if I cant find any wheels :)
Posted 17 December 2013 - 06:38 PM
the mini wheel's will be fine on there unless you've had to fit wheel spacers or something like that
your only concern is the tyre touching the body, or the hole in the centre of the wheel not being big enough for the sticky out bit around the drive shaft nut.
Posted 17 December 2013 - 06:50 PM
Okay well the mini wheels fit onto the four 'prongs' that are around the castle nut, I was just worried about the strain..
There is no rubbing or anything which Im happy about.. I should take a picture really, tomorrow!
Thanks mini13
Posted 18 December 2013 - 11:30 AM
no problem,
to put your mind at rest furthur, the metro turbo wheels end up in a similar position to where your mini wheels are, so you are not pusuing it outside of its design,
also some people fit metro parts to minis and use them with mini wheels.... or 7x13, which move the wheel out drastically with no issues.
I will say, while you are working on the car, it is worth checking the joint where the front anti roll bar goes through the bottom arm, and also the top and bottom ball joints,
