Hi,
I'm rebuilding my A+ gearbox (DAM 5626) fitted to my '85 Mayfair and currently trying to remove the 1st motion bearing. I failed at trying to drift it so using a slide hammer (Clarke CHT251) and now make an adapter to join them.
Plan is to use 30mm round bar and tap each thread into each end. I think the slide hammer is M16 fine but sent Clarke an email to confirm. Hopefully I'll hear back. The question is what thread is on the 1st motion shaft? I belive it is UNEF 3/4" or 7/8" but not sure. Can anyone shed any light?
Dan
No replies to this topic
Posted 30 July 2013 - 02:11 PM
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
