Hello all...
need some advice... Im having issues with the turbo...
When the engine is cold the turbo works great... but once it does warm up the turbo looses boost at the 2500 rpm Range... but it still works in the lower range... just when the engine is warmed up do i lose boost past 2.5k... I had a look at the turbo and also a Mech and i was told that it's only got 25% life left in it... and i have no check engine lights...
i have searched google and there is a wide range of people talking about sensors... and some are saying that the veriable splines in the turbo might be gummed up... (which i would think would cause it to be gummed up all the time and not just when warm...)
so i thought that i would ask you guys here and get your thoughts...
Thanks...
Mat
