A Complete Noob Doing A Turbo.... (Eventually)
64 replies to this topic
#16 t@z
t@z
  • 1,712 posts
  • Local Club: www.turbominis.co.uk
Posted 14 July 2013 - 07:48 AM
just to add about people saying supercharger power blah blah turbo spool up.  my t2 was never off boost really even in low revs cause its such a weeeeee turbo
Edited by t@z, 14 July 2013 - 07:48 AM.
#17 Miniac86
Miniac86
  • 334 posts
  • Local Club: MOCKZN
Posted 14 July 2013 - 09:38 AM
The smaller the turbo, the faster the spool up to get you on boost. In the long run you'll extract more power out of a turbo than you would with a S/C. Personally, I'm going the S/C route with the aim of going turbo in the future.
#18 mini13
mini13
  • 3,810 posts
Posted 14 July 2013 - 10:06 AM
feel free to sticky it, if its of help the great!
if there's any thing else that any one wants covering let me know and I'll add it.
Edited by mini13, 14 July 2013 - 10:11 AM.
#19 toyboy396
toyboy396
    Grandad in training.....
  • 1,000 posts
  • Local Club: C&T Classics
Posted 14 July 2013 - 08:52 PM
To be honest thats a great guide, mind if I add it to FAQ's, You'll get credit!!
Thanks  ;D
:lol:
#20 craigr91
craigr91
  • 429 posts
  • Local Club: nwminiclub
Posted 19 July 2013 - 06:49 AM
As a complete noob I've never done owt like this before and I'm gonna slowly go ahead with mini13's suggestion, first question is as well as reboring the block to +20 though, Is there anything else I should get done while its at the machine shop
#21 craigr91
craigr91
  • 429 posts
Posted 19 July 2013 - 10:10 PM
Think I'm gonna go with 12g940 head, so what will I need do to head and block to make it right? Does block need pocketing and head skimming etc?
#22 mini13
mini13
  • 3,810 posts
Posted 19 July 2013 - 10:17 PM
just gerneral rebuild stuff, get the block bored to the pistons and new cam bearings put in if they look worn, get the crank checked out and regreound.
If your using a mild enough cam (as you probably will be in a turbo motor) you woint need to pocket the block, I'd sugest poping the cam your gonna use in the block, and pop the head on and rocker gear with some blue tack on the valves, turn the cam over and see how much it swishes the blue tack out...
the head wont need skimming, but may need some material taken out of the chambers to get the compression down, but you need to know the pistion dish first.
#23 craigr91
craigr91
  • 429 posts
Posted 19 July 2013 - 10:36 PM
A lot of that's gin over my head but I'm sure if I google some stuff it'll come to light :) what can would you recommend?
#24 mini13
mini13
  • 3,810 posts
Posted 19 July 2013 - 10:39 PM
std 1275 metro cam.
#25 craigr91
craigr91
  • 429 posts
Posted 19 July 2013 - 10:54 PM
Thank you and hopefully all should be well with your recmended 15cc fished pistons and 1275 cam and 12g940 head :)
These pistons what I after too?
Told you I do t have a clue ;)
http://www.minispare...px|Back to shop
Thankyou
#26 craigr91
craigr91
  • 429 posts
Posted 20 July 2013 - 03:56 PM
Considering copying this guide
http://www.turbo-mini.com/62147.html
Will I really be expecting more than 130bhp max? He saying 140 with t2 .....
#27 mini13
mini13
  • 3,810 posts
Posted 20 July 2013 - 03:58 PM
Yes the 70773's will be ok, will_h on here ran a set of those for several seasons at 120hp,
with those parts your looking at a compression ratio of about 8.2:1 which is plenty low enough,
#28 mini13
mini13
  • 3,810 posts
Posted 20 July 2013 - 04:01 PM
thats a very good guide, 130+ is possible, but I'd expect a bit lower
#29 craigr91
craigr91
  • 429 posts
Posted 20 July 2013 - 04:29 PM
So a 998 +20 thou and pocketed to accept 12g940 head with the 70773 pistons, using a 1275 metro camshaft, gt17 turbo, mpi tank and fuel pump, metro fuel reg, metro turbo carb and plenum chamber, std mini gearbox with minispares x-pin diff and that all I gathered ATM, obviously need fuel return pipe into tank?
And okay let's say 100bhp? How "fast" is 100bhp mini?
#30 mini13
mini13
  • 3,810 posts
Posted 20 July 2013 - 05:14 PM
100hp is easily realistic,
100 hp is pretty quick, basically the ERA turbo was a shade under 100hp, and that is booked as 0-60 in under 8 secs and top speed of 115mph, the 998 wont quite have the same torque, but you'll probably have a later car than an ERA, so I think you can expect similar or a bit better.
