Phoenix Estate Vvc K-Series Diy Subframe Conversion
212 replies to this topic
#76 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 03 February 2014 - 10:49 AM
Looking good. Fast progress!
#77 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 12 February 2014 - 10:01 PM
Had to take some time out to make a pond cover, because my toddler is getting a little adventurous,
But just quickly put the steering rack and subframe on.
Looks like the nice hole I cut out for the gearbox is neatly filled by steering rack.
Bugger.
DB8BE553-A46B-401A-AD19-8C5727EE704B_zps
I'll offer the engine and box up to make sure, but looks like I'll have to move engine and gearbox mounts forward.
Not too bad, a unless I have to re-do the bottom arms too...
We'll see
#78 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 12 February 2014 - 10:03 PM
Im sure some who have DIY framed a k-series have moved the steering rack inwards by modifying the toeboard area.
#79 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 12 February 2014 - 11:51 PM
Cheers Jordie.
That's very possible. I could just cut out that whole bit and re 'glass it back in a couple of inches further back. Might need longer track rod arms tho...
Edited by Alburglar, 12 February 2014 - 11:51 PM.
#80 Minidarren83
Minidarren83
  • 1,207 posts
Posted 13 February 2014 - 12:19 AM
Cheers Jordie.
You shouldn't need to really mine is tight but I've got about 10mm clearance
#81 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 13 February 2014 - 12:25 AM
Fingers crossed...
A quick google csme up with triumph "Spitfire ends, which are the correct thread (1/2" unf). they are only 5mm longer though (90mm end to end)" mini ones are 85mm (1/2" unf).
Mini shops sell long ones too, for cars running lots of negative camber.
Edited by Alburglar, 13 February 2014 - 12:26 AM.
#82 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 14 February 2014 - 11:50 AM
Looks swell!
#83 MrBounce
MrBounce
  • 2,641 posts
Posted 14 February 2014 - 01:24 PM
Fingers crossed...
Same ones my friend!
#84 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 20 February 2014 - 07:56 PM
Gearbox does hit the steering rack
F23B2B17-B624-4138-AB0C-4A9C1E74C711_zps
I could have moved all the engine mounts forward, but engine would have been way out past the wheel line and I fear it would have handled *******.
Plus the pg1 driveshafts would have fouled the frame in this position.
F567574D-F452-42FE-B416-6E9B73E69558_zps
Edited by Alburglar, 20 February 2014 - 07:56 PM.
#85 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 20 February 2014 - 07:59 PM
So I cut round the steering rack and moved it back. I just put a couple layers of grp in the middle and have left it to set. I just want to hold it in place for the time being.
AFD6FCAC-3564-4D90-8C54-980B77EB6592_zps
#86 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 20 February 2014 - 08:01 PM
Engine now sits in nicely.
05743372-6DE8-4B84-B079-0A9CCA9C382E_zps
#87 hoody99
hoody99
  • 699 posts
Posted 21 February 2014 - 11:38 PM
That's one big roll of fiberglass lol good work tho chap keep it up
#88 Minidarren83
Minidarren83
  • 1,207 posts
Posted 21 February 2014 - 11:56 PM
The normal thing to do with the k series is to bring the bottom arm mount backwards and modify the standard bolt you may find your mounts will just shear off
#89 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 22 February 2014 - 11:29 AM
Agreed. I have no intention of leaving that be as it is. It definitely needs beefing up. Current plan is to link it all up replacing the cut out part of the subframe tower with a removable alternative.
#90 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 22 February 2014 - 08:41 PM
...although what you've done there does make loads of sense if drive shaft clearance is gonna be tight....
