Phoenix Estate Vvc K-Series Diy Subframe Conversion
212 replies to this topic
#31 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 31 July 2013 - 11:28 AM
4C1DAFDD-4D66-4BCD-B0AA-3F587C223BC3-664
Should probably get the title of this thread changed really. If any mods are watching could you please change it to:
"Phoenix Estate VVC K-Series DIY Frame Conversion"
#32 Minidarren83
Minidarren83
  • 1,207 posts
Posted 31 July 2013 - 06:40 PM
Not sure if you have tried the engine in there yet or lined it up next to it but you may struggle getting it in there as the front bar is not far forward enough or your bottom link alarms might not clear the sump but you never know lol
#33 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 01 August 2013 - 07:28 AM
Work in progress...I've got to bend a bar that will replace the majority of the front. should create a 'bulge' in between the front mount holes. The Phoenix front end has a lot of space there.
Cheers for the 'heads up' tho Darren, any other foresight from folks who've done one is appreciated.
...so front bar next, trial fit in bay, remove and offer engine up...
Edited by Alburglar, 01 August 2013 - 10:36 PM.
#34 scaffers
scaffers
  • 476 posts
Posted 01 August 2013 - 02:12 PM
you have some skills on tap my friend.
#35 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 01 August 2013 - 10:35 PM
LOL. Thanks
#36 Mini-Mad-Craig
Posted 02 August 2013 - 11:48 AM
Very nice work mate. Are you going to be using K-Series running gear hence 95.25pcd or do you have another trick up your sleeve?
#37 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 02 August 2013 - 02:01 PM
It will be mini running gear (hubs, suspension arms, tie bar) with diy drive shafts. Probably coil overs up front.
#38 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 04 August 2013 - 09:13 PM
00D46000-33E1-4A45-9300-E8E5EEA3BEF0-808
#39 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 04 August 2013 - 09:15 PM
Bent Front bar added to help with exhaust manifold clearance.
#40 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 06 August 2013 - 10:40 PM
Not an overly productive day.
416 engine side mount, needs shorter bolts than mgf mount, and i didnt want to cut up the mgf mount (incase i change my mind and use it) so needed 54mm spacers made up. I will weld a fillet between them at some point.
EB41266F-2A0C-43AF-83DD-C6D9E6C33425-883
I used the crap style mini ball joint remover to get the pg1 driveshafts out. It worked a treat.
The engine needs tipping up engine mount side to get the gearbox past the subframe bar, so every te you do it all the oil comes out the empty drive shaft holes -doh! So I've welded some extensions on and spaced the subframe arms out.
E577971F-0376-491B-88A9-D39A6FD98FBB-115
Oil filter housing sender fouls the frame too, so I made up a tempory blanking plate. I can either fit a remote filter housing or mod the frame a bit more.
77426EF6-B992-491A-BC5E-76EC55087379-883
Also one bolt on gearbox hits the frame and so does the sump mount bracket. I have a plan but ran out of time. I might just mod the sump bracket rather than cut the frame.
Edited by Alburglar, 16 August 2013 - 09:36 PM.
#41 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 August 2013 - 09:28 PM
Had an afternoon free today.
Still a work in progress, but This is how it looks for now:
B41236DD-6B19-4125-B0ED-6B09B06FBF1F-115
I have left the tube off the gearbox mount side for the time being. I'll leave it till the last minute When I know exactly how it sits.
The gearbox bottom bolt still hits the frame here so I need to sort that.
664669C5-CE2C-490F-B11E-0F6DB91BDB19-115
And sump mount fouls the frame here, on the opposite side. I'll probably extend the sump mount bracket to move it over a bit
769BC9D2-A2F8-45FF-A9D5-B88EB7D02901-115
I had to cut quite a lot of the frame away here to clear the gearbox and linkage so I've added some bars for support:
D2769F6C-6AAC-42AC-B5E6-B893C48728EA-115
But it needs some triangulation
3053B45E-5028-4621-9502-3BBC0D707DB5-115
ACC60B58-5E82-45BD-898A-33620438D06C-115
Edited by Alburglar, 16 August 2013 - 09:44 PM.
#42 MrBounce
MrBounce
  • 2,638 posts
Posted 18 August 2013 - 08:40 AM
Am fascinated by this :thumbsup:
And it's nice to see someone else whose fibreglass bodyshell is in a bit of a crap condition!! :teehee:
#43 [email protected]
[email protected]
  • 152 posts
Posted 21 August 2013 - 09:57 PM
top build!
#44 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 24 August 2013 - 03:21 PM
Not a lot done, but I've made the gearbox leg removeable as it will make clutch changes much simpler. Plus I wanted that done before I started to cut the frame to clear the gearbox bolts.
632BF151-06F5-4C0E-A4AB-E2B890B8DC3D-138
4A16087F-B016-4375-9CA8-6C15A59A98C0-138
Edited by Alburglar, 24 August 2013 - 03:24 PM.
#45 Peskett
Peskett
  • 278 posts
  • Local Club: 16v Mini Club forum
Posted 24 August 2013 - 07:53 PM
Have you tried your engine in the frame yet? Do your two lower side bars clear the sump? I've had to go around my sump and ground clearance between sump and floor is minimal as it is. You may be able to mount your engine a bit higher than me being a clubby front.
