Phoenix Estate Vvc K-Series Diy Subframe Conversion
#16
Posted 16 July 2013 - 07:01 PM
#17
Posted 19 July 2013 - 07:30 PM
It is no better fit at all and I haven't even got the steering rack on it. The Phoenix 'clubman' front must be the same length as a round nose, because it needs extending by about 90mm to fit, which I'm not interested in doing.
to make it sit within the Phoenix front end I'd have cut the rear off here (pens mark the spot) and fit the steering rack inside. Or cut the bulkhead drastically and grp a new one in. Which I am also not interested in doing.
Time to order some more cutting discs and have a go at the mini frame.
Edited by Alburglar, 19 July 2013 - 07:31 PM.
#18
Posted 25 July 2013 - 12:07 PM
#19
Posted 28 July 2013 - 09:37 PM
Just wanted to say there is another phoneix on a q plate for sale on ebay. Regards Blue
#20
Posted 29 July 2013 - 01:28 PM
There was one last week on eBay too, also on a Q plate went for under £400
It was complete but abit rotten looking.
Really cool project by the way! :)
#21
Posted 29 July 2013 - 05:22 PM
#22
Posted 29 July 2013 - 05:24 PM
#23
Posted 29 July 2013 - 05:47 PM
Just waiting for rover 400, 45 engine mounts to arrive. Look much simpler than mgf ones
Have you decided what to do with the front frame? I've almost finished my mini based frame and fits under a standard round nose with the pg1 box so should fit under the clubman front
#24
Posted 29 July 2013 - 07:10 PM
Yeah gonna use the mini frame. Just gathering bits. Just bought a mini MPI loom too as they are mems 1.9 so mems 1.9 or 2j or 3 ecu should plug in.
#25
Posted 29 July 2013 - 07:12 PM
what mounts did you use darren?
#26
Posted 29 July 2013 - 07:44 PM
Out of interest what are these listed as on the v5?
Ive reg checked a few that have come up for sale and they always say "Other" or "Other British Make"
#27
Posted 29 July 2013 - 08:04 PM
Mine says "Make: leyland Cars" and Model is unlisted.
#28
Posted 29 July 2013 - 08:08 PM
That's exciting!!
#29
Posted 30 July 2013 - 07:13 PM
I used the standard ones that came with the engine when I pulled it from the car which was mg zr, engine side and standard bobbin type on the gearbox most people use the rover 400 bubble types on the engine side.
Have a look at my thread to see the frame I built and mounts I used
http://www.theminifo...27#entry2858910
#30
Posted 30 July 2013 - 10:32 PM
I used my pipe bender for the first time. It bends round tube and even went well with square tube. I did this:
And then cut out the sides
Just waiting for my engine mounts to turn up and get my engine hoist back off my mate. Then hopefully I'll wriggle the engine in.
