Phoenix Estate Vvc K-Series Diy Subframe Conversion
212 replies to this topic
#181 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 08 June 2015 - 07:13 PM
I was after a small Nippon Denso alternator and some people have found them in Daihatsu Charades and such like. I took a chance on this one cod it was £12. But it's only a little bit smaller. Fail. I'll post up all the info I have so other people don't make the same mistake.
SUZUKI ALTO 2005 ( 03-06 ) 1.1 16v ALTERNATOR
TAKEN FROM A NON AIRCON MODEL
DENSO MAKE
PART NUMBER 31400-79G00 / SR102211-5610
63431C9D-4E21-421E-A20E-2C0D8BCA05F1_zps
#182 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 08 June 2015 - 07:16 PM
Before my welder started buggering about, I got the gearbox mount done.
A6F00F0C-FE95-430F-8792-7220B4CCD811_zps
I cut off the extra support and covered the notches in the lower leg
1DB4D492-9CCC-42AE-B5FF-E0B7F8B82877_zps
#183 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 08 June 2015 - 07:18 PM
I cut the o/s driveshaft hole bigger and then welded the seam for strength.
23F51208-BB0E-487E-B249-7843F2E61A35_zps
Ditto for the n/s driveshaft clearance.
E4FF0ABD-1BD6-4A32-89DB-4D2BFDF1F75E_zps
#184 69k1100
69k1100
  • 376 posts
Posted 08 June 2015 - 08:49 PM
You could flip the alternator too so the body sits towards the wing. Just need custom mounts.
#185 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 08 June 2015 - 09:20 PM
I'll have a look into that.
#186 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 08 June 2015 - 09:58 PM
You can run it backwards and put it under the wing if you want ...thats how my swift runs its alternator
#187 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 30 July 2015 - 04:42 PM
I spent just as much time fixing my welder as I did welding today, but I got a couple of bits done.
I re-inforced the front corners as planned.
CC4332FC-7CAE-4ED0-9225-618A7D15782F_zps
979623F8-D581-48F4-AE79-E43EFC7482F7_zps
#188 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 30 July 2015 - 04:44 PM
And then finished off the engine mount by adding a support.
8685198F-8911-4AC7-90BA-285729A7CDB0_zps
#189 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 30 July 2015 - 04:57 PM
...and I think that's it, so I might even risk painting it next time.
I'll have to finish off the body work on the front end at least and hopefully start bolting stuff in, in their final positions
Body work jobs are :
Sand out the gel coat cracks on both sides of each panel and re-glass them.
Make the shut lines,where I cut off the front end nice, by re-glassing them.
I need to fix the hole I cut in the bulkhead, under the master cylinders, when I was trying to figure out clearance for the old inlet, which I've now ditched in favour of OE inlet.
...and if I remember correctly, once I'd fitted the steering rack, I wasn't 100% happy with the clearance on the drivers side gaiter, so I may have a go at that, whilst I've got the sticky stuff out.
I'm also debating on doing loads of grp on the inside roof edges and rear corners and tailgate, then sanding the horrible 'Phoenix' roof lines into something more mini estate/ van like.
But I reckon it'll add 50hours to the build.
I may just leave it and use a white carbon effect vinyl on the roof, as the old general lee vinyl made the roof look ok. I think the main car colour will be almond green....
Edited by Alburglar, 30 July 2015 - 05:09 PM.
#190 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 18 August 2015 - 06:15 PM
Boxed some ends off today.
3B0FB16B-3B15-443E-8FD3-3F62DA268251_zps
#191 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 21 September 2015 - 09:05 PM
Subframe is painted.
6D95F188-509E-4DAD-AEA3-F05E366F88C0_zps
#192 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 21 September 2015 - 09:11 PM
Then I've been sanding like a loon to get ready to fibreglass stuff.
These shut lines need tarting up.
7827402F-BDE5-481D-82CA-3620A430B4FA_zps
023D2B59-089B-4A4C-90F4-A02CDD9DE61F_zps
This crazing needs taking right back and reglassing.
21CE8856-AF3F-4CB9-9A00-7E6737B7763E_zps
9AD830E0-6743-4565-B251-8F4D9F116856_zps
Smoothed the inner wings of the removeable front.
4301E178-0F1F-490C-ADA1-3E122E408FA3_zps
6D25D488-6EBD-4326-BF91-5EEA9310B50A_zps
#193 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 21 September 2015 - 09:15 PM
I also filled the hole I cut in the bulkhead to clear the old inlet. This was a minor disaster as the bottom started to peel away, but I taped round a block of wood and used that to pin it back. I should think it will need sanding and re-doing half of it tho.
B0731B77-A7E3-4317-9184-E09630749A23_zps
#194 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 21 September 2015 - 09:22 PM
I don't know how to sand the bonnet gutters tho, asides from a thin baton of wood with sand paper round it.
Any bodywork people know a better way?
#195 spike 25
spike 25
  • 322 posts
Posted 10 November 2015 - 08:22 PM
Might be worth giving Stuart a call at CSG Bodyshop he knows a trick or two :-)
