Phoenix Estate Vvc K-Series Diy Subframe Conversion
212 replies to this topic
#151 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 06 October 2014 - 03:41 PM
Can you not lean it rather then move it?
I'm afraid not. It would be a very drastic lean and then drive shaft holes would be blocked by the frame.
...although I could tilt it using the drive shaft holes on the frame and gearbox as a point of axis and the just re-do my engine mounts and sump mounts, but I had considered that already, albeit briefly, and it looked like it would foul the master cylinders reservoirs, but I could go for remote reservoirs.
Lots of options really, if it runs like a bag of ******* with new inlet, but we'll see.
I may try and flatten the bottom of the round tube rather than use the square tube. I think ID of inlet goes down to 38mm so area is 1134mm sq an rectangle box is 714mm sq so too restrictive, but I'll double check.
Edited by Alburglar, 06 October 2014 - 03:56 PM.
#152 kcchan
kcchan
  • 874 posts
Posted 06 October 2014 - 08:01 PM
That manifold would have been terrible for flow. Sharp transitions and a dramatic change in profile would kill any air velocity. You're better off either moving the engine forward or maybe getting some 90* bends straight off the flange and up
#153 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 06 October 2014 - 10:54 PM
...no space for bends, that's the issue...
#154 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 06 October 2014 - 11:03 PM
...and it is a 150bhp road car, I am not attempting to squeeze 100% power out of a race engine. Air velocity is not concerning me a great deal. Plus whilst it's apart in can polish all the internals of cast parts, which already angle up to some degree.
Nothing ventured, nothing gained and at £20 a manifold It doesn't matter if it's a fail.
#155 geachy87
geachy87
  • Just Joined
  • 48 posts
Posted 07 October 2014 - 04:15 PM
What angle does the bottom of the sump sit at compared to the floor? The k series engines lean forward quite a bit as standard, yours seems to be sitting pretty much straight up and down, although it could just be the angle of the pictures
#156 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 08 October 2014 - 08:40 PM
Mine is pretty flat as you say. I've had two vvc metros tho and don't recall either of those being particularly slanted. Although they were r65 boxes not pg1. I will certainly have a look at tilting it before I do anything else.
#157 geachy87
geachy87
  • Just Joined
  • 48 posts
Posted 08 October 2014 - 09:59 PM
EDDB57F2-6831-4011-9486-6CAE536E25F1_zps
Gives you a rough idea on the forward lean in these pictures
D1908AA1-4A92-44FF-9DD0-7D5FE54A6103_zps
#158 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 09 October 2014 - 06:45 PM
Thanks.
I had a look today and tilting it looks like the alternator might hit the frame and possibly leave no space for oil take off plate, without major frame changes,
83FE532D-8283-44D4-B61C-08A13C3476FD_zps
plus new engine and sump mount, so not an easy fix. I will give it a go though when I next take engine out after I've made the jig for new inlet, just to see if it's worth it.
Need to get hold of the oil take off plate to make sure that fits and offer the front end up to make sure the alternator has clearance too.
I also removed, cleaned up and fitted some top arms.
Edited by Alburglar, 09 October 2014 - 06:46 PM.
#159 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 09 October 2014 - 07:51 PM
ID of inlet actually goes down to 36mm which works out at 1017mm sq, but internal area of box section is bigger than I thought and is about 840 mm sq. I may make the effort to mod the pedal box a little to get the round tube in at 1257mm sq, it would certainly help with any air flow issues.
Edited by Alburglar, 09 October 2014 - 07:52 PM.
#160 geachy87
geachy87
  • Just Joined
  • 48 posts
Posted 09 October 2014 - 10:11 PM
Are you using the standard oil filter set up or a remote one? I take it it'll be remote given the space you have to work with?
#161 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,740 posts
  • Name: Chris
  • Local Club: None
Posted 10 October 2014 - 07:48 AM
I've just seen this on the bay of e http://www.ebay.co.uk/itm/181550150212
#162 geachy87
geachy87
  • Just Joined
  • 48 posts
Posted 10 October 2014 - 07:58 AM
That's ardonfast's off the 16vmini forum, aparantly quite rare
#163 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 10 October 2014 - 06:08 PM
Here is the remote filter take off I have ordered from jlhmorrisminors. I was going to make one, but this is exactly what I was going to make, so silly not to...
942A4E93-CCE3-43FD-9266-9E0B928204D2_zps
Pictures of it fitted are in this link
http://www.jlhmorris...ent/k_more.php#
...edit: just figured out how to do screen shots!
1C2EE3E1-E6B5-4B59-A946-F39E6C8A6064_zps
Little alternator that jlh used on their moggies looks just the ticket too!
4401D22D-F26A-4392-9BF4-B1176DA119FB_zps
Edited by Alburglar, 10 October 2014 - 11:01 PM.
#164 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 10 October 2014 - 06:09 PM
...err and yes there is a reason they only made a few minus maxis!
Not that a Phoenix is to everyone's taste...
#165 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 11 October 2014 - 08:40 PM
What arrived was slightly different to jlh website. It is a mocal / thinkauromotive item.
32mm without the gasket so should work.
50251B6C-729C-45AF-8A74-5DD88E512F37_zps
Edited by Alburglar, 11 October 2014 - 08:40 PM.
