Phoenix Estate Vvc K-Series Diy Subframe Conversion
212 replies to this topic
#136 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 12 September 2014 - 03:49 PM
Made some more clearance.
D524BCFF-8763-414E-AE30-57BB4E688C56_zps
Made it sound again, by re-inforcing the seams. Couldn't add too much material here because of clearance.
90376465-2E2C-43D4-877D-DE343CE5A979_zps
So re-inforced it some more from the rear
93E89B1E-36F3-402A-870C-CE21C8817C9E_zps
Just got to sand it when dry and Hopefully this will be the last time I have to do this!
Edited by Alburglar, 12 September 2014 - 05:54 PM.
#137 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 12 September 2014 - 03:53 PM
Also made one good steering column out of two knackered ones today, along with a freebie steering wheel and boss. Cheers Pinch.
#138 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 12 September 2014 - 03:54 PM
Boring pic, but it replaces a double post.
4D71AB19-6AF5-4D63-A8A8-71A3FF299A94_zps
Edited by Alburglar, 12 September 2014 - 05:45 PM.
#139 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 01 October 2014 - 01:56 PM
Well I am a total arse.
Everything in, with what I thought was loads of space for the inlet manifold.
9E91F0C5-5070-4B91-AD1E-97567ECF58FB_zps
Or not. School boy error,
B61120BE-C81F-4FFF-9B03-E92901777A25_zps
1F1425C8-10E7-4C0E-9CDA-CCB25DEFBD26_zps
It's right where the pedal box and master cylinders are so I can't even put a bulkhead box in. I could but a floor mounted pedal box in but I want to be able to put back to standard if I ever fancy it. So either a custom inlet or move engine forward. Bugger.
#140 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 02 October 2014 - 07:09 PM
Ok so I need to shorten the inlet manifold. And then offset the air box higher and more central (further to the right) by raising the flange the air box bolts to on the manifold.
So here's the plan:
39BF47AD-7764-4E4C-AFAF-56D83673014D_zps
Air box and manifold.
D2CF97A4-3A39-4CCA-89DF-6EFBF4D7B139_zps
Manifold with injectors
19262C3E-4242-46DB-A7CC-150AA3773B97_zps
#141 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 02 October 2014 - 07:14 PM
Got some 48mm tube.(not 45mm).
Gonna go together something like this but the tubes will be 200mm+ and the air box flange will sit on them.
A175BBAB-BB8E-48C2-9635-B435A399187C_zps
FBD4C78F-F560-4DFF-8A70-62FF99A30242_zps
I can't make it too short and still use stock injector position, so Bulkhead will need some attention, but standard mini master cylinders should still fit if it all goes to plan
#142 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 October 2014 - 01:27 AM
I'm going to assume your bulkhead is standard sized compared to a normal mini if it is just move the engine forward I've got mine in with only a small mod to the bulkhead it also looks as your engine is fairly high too
#143 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 03 October 2014 - 04:16 PM
I do not really want the engine any further forward. It will handle much better where it is, with the weight as far back as possible. But we'll see, if I can't make this work, then I will have to.
#144 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 03 October 2014 - 04:23 PM
I've had to change from the round bar route and gone for some 50x25 rectangle box section, so the manifold is cut flush now.
FD57448F-C9E6-4900-82CD-95E7EA219168_zps
The 48mm tube won't fit and I can't fit them any closer to where the injectors sit. But the box section will work. It will come off at this angle...
CA77F285-4455-474F-B33C-8897A6995AE7_zps
...and the inlet we end up here, much further over to the right.
10388AE6-3107-4F62-B29B-2F94ED3FA672_zps
I've cut the top flange flush
2E41E239-36F1-4BD8-9CAA-0C573E3F0F80_zps
#145 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 03 October 2014 - 04:25 PM
Next step is to build a jig to test final fitment and to make sure everything is in the right spot when it gets welded up .
880E5B66-BB76-44E4-BF65-771FE46132A4_zps
479B1970-056F-490B-A8DF-82B229F9A86D_zps
#146 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 04 October 2014 - 11:56 AM
Due to some new input, I'm worried now that the required inlet changes could bugger up the engine map and performance.
Perhaps I should just bring the engine forward, so standard inlet fits like everyone else. It does mean changing my whole frame tho, as lower bars wrap around the engine with no room to play with. But if inlet works, then it will handle much better with engine where it is.
But floor mounted pedals would fix all issues, but the bulkhead box required for standard inlet would put shell past point of no return for ever bolting standard mini parts back on it.
I think I will recon my hubs ASAP, fit them and have a proper look at driveshaft position, before I make a final decision.
But I'll probably persevere with the inlet and just try it!
...making this whole post, utterly pointless. For that, I apologise.
#147 Archived1
Archived1
  • Archived
  • 619 posts
Posted 06 October 2014 - 08:57 AM
Can you not lean it rather then move it?
#148 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 06 October 2014 - 01:43 PM
I'm afraid not. It would be a very drastic lean and then drive shaft holes would be blocked by the frame.
#149 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 06 October 2014 - 01:48 PM
Remap it? :)
#150 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 06 October 2014 - 03:33 PM
Entirely possible if required, but Mems 2 isn't mapable...so that requires a mems3 conversion (new ecu, loom section, cam cover and coil packs plus an extra sensor I believe)and z&f remap or forking out for an emerald ecu.
