Replacement Clutch Slave Cylinder
8 replies to this topic
#1 1977Sagren
1977Sagren
  • 34 posts
  • Local Club: MiniOwnersclubkzn
Posted 06 July 2013 - 07:28 PM
Hi all
I would like to know if anyone has tried using another car slave cylinder on mini clubman 1977.My car is a pre verto clutch.My reason for asking is because I am from South Africa and the guys that sell spares here are way over priced on mini spares,I am thinking of using a 1992 corolla slave cylinder.Has anyone gt any ideas or point me in the right direction as to how I can use another slave cylinder.
Thank you in advance.
#2 krusher74
krusher74
  • 127 posts
Posted 06 July 2013 - 07:33 PM
Have you looked to see if you can do a rebuild with a much cheaper rebuild kit?
#3 1977Sagren
1977Sagren
  • 34 posts
Posted 06 July 2013 - 08:13 PM
Hi Krusher
My Slave broke at the nipple point it is unusable.Thank you for the quick response
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 July 2013 - 09:05 PM
Bore and stroke size are your issue, you need to be the same on both to ensure it would work
#5 Ethel
  • 25,922 posts
Posted 06 July 2013 - 09:20 PM
You could probably bleed a clutch slave successfully through the hose union. Just slacken the hose and push the cylinder piston back in with a stout screwdriver. Hold the pedal down to stop it feeding back to the master.
You could also drill out and replace the bleed screw with summet like http://compare.ebay....ff13=80&ff14=66
Though any 7/8" bore cylinder with enough stroke will do, if you can mount it.
#6 1977Sagren
1977Sagren
  • 34 posts
Posted 06 July 2013 - 10:07 PM
Hi Ethel
Will a different size bore cause any problems or if I get the same bore will it work
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 July 2013 - 11:49 PM
Bore is important as incorrect will mean different pressure, to big the master cylinder wont stroke far enough
#8 Miniac86
Miniac86
  • 334 posts
  • Local Club: MOCKZN
Posted 07 July 2013 - 08:54 PM
Hey Sagren, have you spoken to Doug about a price?
#9 1977Sagren
1977Sagren
  • 34 posts
Posted 11 July 2013 - 08:54 PM
Thanks to all repies I managed to source second hand. 1 .
