I recently bought a MK2 golf as a new daily driver.
It had its problems but is sound body wise, needs a good polish.
Problems
- high idle / running on intermitantly
- wiper stalk broken
- bit of interior trim missing
Today i sorted the wiper stalk with a new one, rewired the mess that someone had done putting in the CD headunit and wired in all speakers, including 2 6x9s on the rear shelf.
The 6x9s were given to me, they are magnet brand with a seperate unit just before the speaker which splits the tweeter and speaker freq.
Head unit now turns off with ignition, but memory 12v feed doesnt seem to work, I will have another look when I get a new headunit fitted.
Ive had a spy at the engine, theres a rubber mount under the carb/throttle body which is split and loose. I will replace this and then see if idle improves etc.
Jordie
