What Do I Need For A 1.4 K Series Build Thanks
Posted 06 July 2013 - 08:05 AM
I have a rough idea of what I need just need abit of guidence
Subframe from allspeed
Drive shafts worked on
Engine bay wiring loom
What else will I need thanks
Also will this fit under a standard round nose
And the standard injection system will hit bulk head what else can I do I.e carbs etc
Posted 06 July 2013 - 08:23 AM
have you went off the micra idea?
Posted 06 July 2013 - 08:25 AM
Donor car with engine, key, immobiliser, wiring loom to salvage
Posted 06 July 2013 - 08:32 AM
should fit under the std round nose but you will definitely want a removable front.
Posted 06 July 2013 - 08:33 AM
Posted 06 July 2013 - 08:40 AM
And that gear box r65u is only needed for the 1.6 isn't it
Posted 06 July 2013 - 08:47 AM
Posted 06 July 2013 - 09:19 AM
Posted 06 July 2013 - 01:06 PM
1.1
some free tuning tips for you. use a mgtf exhaust manifold, a lotus elise throttle body ( shamfer the lip and remove the lip inside the TB ) they will unleash the beast
Posted 22 December 2014 - 11:59 PM
Posted 23 December 2014 - 06:48 PM
Join the 16v Mini club. All the info is all there.
Do hours worth of reading before you start. It will save you loads of time and money too.
Not an easy conversion but well worth it!
Posted 10 January 2015 - 12:43 PM
You can use the pg1 ( c4bm which has the starter at the top rather than the front ) but this is a bit harder to fit in a round nose but gives the best ratios and is a stronger box
As agoaty says join the 16v mini club
Lots of info on there,and if you can't find it there's plenty of guys there that can help
I fitting a 1800 with vvc manifolds pg1 box in standard length round nose
Posted 10 January 2015 - 01:16 PM
As minion and Agoaty above have said, 16VMC is the place to go in respect to what you're asking. What you want to read, to save you searching is this thread right here.
http://www.16vminicl...read.php?t=8625
There seems to be so many options and choices with the K series engines and it really is worth having a good old read. I plan to swap my Vauxhall conversion out for a K series conversion this coming winter and I am still learning a lot.
You seem to have a basic idea of what you are going to need but it will get much longer and comprise of many more parts.
In regards to having a removeable front, yes a lot do look rubbish but they can be done really well, look at Instant Custard and Kam, theirs are fantastic. I can only think of a few cars off the top of my head that have all steel front ends, one is Marks Z18 and the rest have all been micra engines and an incredible amount of work has gone into them.
16V conversions are fantastic in my book, you'll end up looking at your car with a completley different mindset, I do anyway.
EDIT.
Allspeed suggest that with thier frame, with a 1.6 with the plastic inlet it will clear the bulkhead with no need for modifications, as far as I am aware the only time you need to touch the bulkhead is if you are running the cast 160 inlet.
Edited by tomm, 10 January 2015 - 01:18 PM.
Posted 10 January 2015 - 01:31 PM
As for the gearbox, the off the shelf box to use is either the 5C35 R65 or C6 PG1 which is stronger, but bigger.
I am assuming you have a roundnose Mini. Mine was but now has a steel Clubman front welded on.
