Meet 'Gertie'...
...and 'Ute'
Posted 03 January 2014 - 08:26 AM
Posted 06 January 2014 - 10:08 AM
Posted 07 February 2014 - 05:44 PM
Well, not too much to report of late......
Been a bit idle and not been going up the workshop much lately.
Went up the other day while I was waiting for someone to pickup a set of wheels and a few other mini-related bits, so finally welded up the extra steering column brace. to be honest it's a hell of a lot stiffer now but now the cross beam flexes slightly...and that's 1 1/4" seamless 4mm thick steel tubing..... I guess I'm never going to eliminate ALL of the flex. It should be better if (heaven forbid) I should ever front end or roll 'Chop'
Also welded the first of the two harness braces for the rear crossmember... It was a real swine to weld as the space was REALLY tight and I needed to get into all manner of positions that a 40-something overweight bloke is NOT designed to be able to get into .... but 1 is done.....even had to result to welding right-handed EEK!
So..... I'm still on for IMM later in the year and hopefully finish the rest of the bracketry soon, so I can begin the first of the 'dry builds' to make sure I've worked out everything OK
Will need to cut out one half of the rear seat base and a companion bin to give me the space for the 'bed-conversion' although the water and cooking side of things I've already sorted .
Just need to sort out the glass now and I think I've got everything covered....
Cheers all, Andy
Posted 07 February 2014 - 06:28 PM
Look forward to seeing you at IMM
Posted 07 February 2014 - 06:39 PM
Posted 08 February 2014 - 08:25 AM
Last night's 'tinker time' involved slicing out half of the old seat base and lowering the front edge so it doesn't kick upwards at the front and lowering the companion bin top so it would be level with the new base.
The cut base then had a downward facing 90 degree return on it to add a little more strength and it was all zipped back together again with the welder.
The new half seat base is now level with the original front seat crossmember, so I can place the rear covered seatbase cover that I made ALONG the passenger side of the car, turn the benchseat back cushioning along the seatbase cover and swing the whole front seat squab through 180 degrees and put it across the front footwells.
INSTANT (ish) bed for shows etc.
I'll post some photos if anyone is interested?..... Anyhow, after all that cutting and welding, I needed a little rest.... and I'm happy to report that the conversion is comfortable- as my snoring from the garage for the next 1 1/2 hours will testify.....
It's quite comfortable for one, but I fear that it's going to be REALLY 'cosy' for 2..... If I ever find anyone daft enough to want to share
Posted 09 February 2014 - 12:17 AM
absolutely awesome project and fantastic workmanship. hopefully i will be at the IMM so i may see you there aswell
Posted 09 February 2014 - 07:37 AM
sounds good want to see the bed for sure lol
Posted 09 February 2014 - 09:31 PM
For all those that are interested
Edited by 'Chop', 09 February 2014 - 09:36 PM.
Posted 09 February 2014 - 09:48 PM
Facebook Link does not work for me.
Posted 16 February 2014 - 05:00 PM
Just come back from Bristol Classics autojumble....
Not too much there, but had a chat with Stuart King from 'Send him Victorious'. He's making some great mini weekend bags and general classic car/ camper type upholstery, bags/ cushions etc. Find him at www.sendhimvictorious.co.uk Top bloke and he's hopefully doing me a great price on a custom coloured bag for 'Chop'
On another note, picked up a few bits I needed to finish some odd bits.... and a new custom 50's style sunshield.... (see below)
valance.jpg 44.42K
9 downloads
Oh! You all noticed it's currently a rear valance Well, with a bit of cutting, bending, welding etc, I'm sure it'll do the job
Back to the metalwork again.. I love it!!
Posted 16 February 2014 - 07:12 PM
Thanks for those kind words 'Chop' was a pleasure to meet you. Having just looked through the pictures of all the hard work you've put in, I'm feeling kind of under pressure to deliver something outstanding for you! (I now understand what your car looks like - before I saw this, in my head I was imagining 'timber' as in a Clubman woody!). Will keep in touch via PM. Now get back to that metalwork!!!
Posted 16 February 2014 - 07:34 PM
As the link didn't seem to work (don't understand this computer nonsense), here goes the 'bed'
1, The roughed out bench seat
chop camper 001.jpg 159.33K
31 downloads
2 Remove back rest
chop camper 002.jpg 159.58K
14 downloads
3 Remove seat back
chop camper 003.jpg 163.93K
10 downloads
4 Remove passenger seat, place on driver's seat
chop camper 004.jpg 156.54K
16 downloads
5 Place cooker between crossmenber and rear seat base
chop camper 005.jpg 142.22K
16 downloads
6 Remove rear seat base
chop camper 006.jpg 155.75K
8 downloads
7 Place seat base along crossmember/ cooker/ rear seat
chop camper 007.jpg 159.35K
7 downloads
8 Reverse the seat base AHEAD of the gearstick
chop camper 008.jpg 153.9K
10 downloads
9 Place back rest along seat base
chop camper 010.jpg 160.87K
18 downloads
10 Night, night
chop camper 011.jpg 154.14K
31 downloads
Posted 23 February 2014 - 08:58 PM
Some piccies of my latest hammering and banging....
Started with a rear valance and after 3 hours of trimming, shortening, folding and welding.....
I ended up with a 50s style steel sunvisor.
It's still not right, but you get the idea
chop camper 014.jpg 158.28K
35 downloads
chop camper 013.jpg 35.97K
20 downloads
chop camper 012.jpg 30.64K
32 downloads
chop camper 016.jpg 161.16K
49 downloads
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
