Removing Steering Column Shear Bolts
7 replies to this topic
#1 GreenMini17
GreenMini17
    Formally known as Chris-G
  • 424 posts
Posted 30 June 2013 - 10:48 AM
Trying to fit a heavy duty steering column drop bracket that requires the old part to be removed. How does one remove the shear bolts that clamp the bracket & pedal box to the dash rail?
I cannot cut a slot in the head because the pedal box in the way therefore i cannot get a junior hacksaw in. I can get a spanner on the nuts behind but they are extremely tight (im actually assuming they are captive or welded hence why they wont undo).
Any suggestions? Im thinking i might just send it back and use the shitty normal bracket.
#2 Matt @ Surrey Hills Motor Group
  • 49 posts
  • Local Club: Surrey Hills Mini Group!
Posted 30 June 2013 - 10:50 AM
use mole grips or failing that, nice sharp chisel and knock it on the edge to turn it round...
#3 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 30 June 2013 - 11:04 AM
nuts are captive you need to take your time and tap the left over bolt round using a very sharp cold chisel , i myself tack welded using a mig a bolt onto it and slackened/removed it that way
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 June 2013 - 11:19 AM
A lot of the time the heads are still there so you can use a spanner/ socket VERY carefully. Otherwise a dremel can be used to cut a slot in the head and then use an impact driver. If all that fails, the chisel method described above never fails but is awkward to do.
#5 Barman
Barman
  • 1,068 posts
Posted 30 June 2013 - 11:20 AM
I simply undid mine as whoever put them in didn't bother to shear them off! :lol:
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 30 June 2013 - 11:21 AM
The nuts are not captive as such. well they are, but they're on a plate.  This means you only need to remove the head of the bolt, pull the plate out, THEN you can get somethign on the remaining threads in the plate- which is a lot easier.
Just use a drill up there, that's what i did. It's not easy to keep the drill centre while working upside down, so have a hammer and chissel ready to the head off with just incase you go offcentre.
Hope this helps.Steve.
Edited by JustSteve, 30 June 2013 - 11:22 AM.
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 30 June 2013 - 06:18 PM
High speed grinder with a carbide burr. Works every time. The chisel will work as well.
#8 GreenMini17
GreenMini17
  • 424 posts
Posted 02 July 2013 - 06:54 PM
Thanks guys, the cold chisel and lump hammer did the trick. What an absolute sod of a job though!! Wont be doing that again in any hurry.
