Info On 1.3 16V Micra Engine In A Mini
30 replies to this topic
#16 minilee94
minilee94
  • 3,523 posts
Posted 30 June 2013 - 02:09 PM
Thanks alot mate yeah its not bad to be honest how will the driveshafts line up and im waiting for a reply from a guy in the 16v forum to reply to me about makeing me a subframe up
#17 l_jonez
l_jonez
  • 1,453 posts
Posted 30 June 2013 - 03:28 PM
They line up pretty well, there's a slight angle but nothing the inner and outer cv joints don't take care of.
#18 rids
rids
  • 670 posts
Posted 30 June 2013 - 04:13 PM
mine came in at under £500 but i all ready had some of the bits and i fabricated everything
whole micra £150
steel for frame £40
carbs £60
fuel pump £35
engine mounts £15
shafts welded £35 (i think)
things that i already had
megajolt £250 ish these days
MPi rad and fan £80 ish
the suspension i managed to keep standard with out any modification at all
can just about see that its all normal in this pic
the gear linkage is probably the easiest part,
  1. take the nissan linkage cut it in half,
  2. bolt one half to the car
  3. then the other to the box,
  4. line up the shafts,
  5. mark them up
  6. cut to length
  7. weld back together
i think the question to ask is how many people would go back to the A series? i'd guess that most people who have done this (and other conversions) would not.
its not just the power, its the way a mini drives with this conversion,  everybody thats been in mine have been blown away with the smoothness, the delivery of power and the sheer driveability of the car. they still have the "feel" of a mini but with enough power to have fun but not to much power to spoil the day to day driveability. I for one would certainly do this conversion again.
#19 minilee94
minilee94
  • 3,523 posts
Posted 30 June 2013 - 04:23 PM
Hmm I think ut may be a defo conversion I got my eye open for a Nissan micra and awaiting a reply about subframre
Edited by minilee94, 30 June 2013 - 04:26 PM.
#20 Artstu
Artstu
  • 830 posts
Posted 30 June 2013 - 04:51 PM
Have you spoken to Iain about a subframe? or someone else? Quote from Iain
 I'm also trying to document it enough that I could help other people do it to their cars - Might even look at selling a modified subframe or two if there's a demand or modifying them for people in exchange for beer.
http://www.leylandmi...c.php?f=9&t=752
#21 minilee94
minilee94
  • 3,523 posts
Posted 30 June 2013 - 05:14 PM
Thanks il try him
Also what do I do about power asisted steering
#22 minilee94
minilee94
  • 3,523 posts
Posted 30 June 2013 - 05:17 PM
ahhh Another forum I got become a member of
#23 l_jonez
l_jonez
  • 1,453 posts
Thanks il try him
Forget about it, there's no need for it!
unless you want to fit it as an engineering exercise?
#24 Artstu
Artstu
  • 830 posts
Posted 30 June 2013 - 05:19 PM
Iain's on here too. good luck joining that forum, I tried but never got my account activated.
#25 minilee94
minilee94
  • 3,523 posts
Posted 30 June 2013 - 05:31 PM
lol do you know his user name in here
And okay what go I just remove the pas pump and a different belt and job done and blank of the feed from pas fluid tank
#26 l_jonez
l_jonez
  • 1,453 posts
Posted 30 June 2013 - 05:37 PM
yep, just unbolt the pump, throw it in the bin and fit a diffrent belt (you might need to fabricate a tensioner pulley depending on your set up).
#27 Artstu
Artstu
  • 830 posts
Posted 30 June 2013 - 05:50 PM
the same http://www.theminifo.../40641-ibrooks/
#28 minilee94
minilee94
  • 3,523 posts
Posted 30 June 2013 - 06:03 PM
Okay can you buy a 1.3 16valve with out pas
#29 Artstu
Artstu
  • 830 posts
Posted 30 June 2013 - 06:04 PM
yes
#30 minilee94
minilee94
  • 3,523 posts
Posted 30 June 2013 - 06:09 PM
Okay thank you
