Hello
I have a 1275 cooper s engine i need to rebuild.
The block needs to have the cam bearings reaming, I have fitted new. Bore is good at +40 but might be worth a rehone.
The crank has been crack checked and needs a big end grind and also thinking about a lighten and wedge. probably worth balancing it at the same time
the head is a mk2 940 1805 and needs a skim and new valve seats unleaded and possible valve guides done. Also thinking about getting it ported.
The rods have been crack checked and i think it would be good to get them lightened.
I am happy to build the engine myself just need the machining work done, so my question is who would you recommend and what would you imagine the costs to be like. I am looking for someone who i can trust to do a good job first time seeing as proper s bits are getting rarer.
Would prefer something around the surrey/london area but could travel if the recommendation is strong enough.
Thanks Dave
