Slick 50
24 replies to this topic
#1 venkman
venkman
  • 452 posts
Posted 26 June 2013 - 05:10 PM
What are peoples opinion of Slick 50 or products similar.
I have a rattle that sounds like the valves are loose but i have checked them numerous times and are fine,just wondered if something like Slick would quiten it abit???
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 June 2013 - 05:19 PM
Not recommended for a classic  mini as it shares its oil with the Gearbox and can cause premature wear in the box if the tappets are adjusted right Slick 50 would have done nothing to reduce the rattle, if the tappets are set to there correct clearance then suspect worn rockers at the rocker to valve pad.
#3 venkman
venkman
  • 452 posts
Posted 26 June 2013 - 05:25 PM
How would you go about checking them? Would you have to take the rockers off and measure with vernier calipers or is it more in depth than that?
Would it be a big issue leaving them?
#4 Cooperman
  • 23,278 posts
Posted 26 June 2013 - 06:31 PM
Never put those 'snake oil' additives in a Mini or the gearbox will fail shortly afterwards with no syncromesh left.
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 26 June 2013 - 06:32 PM
Once the damage is done then these products are useless..............I once rebuilt an engone and I used Molislip......and I had no problems when I fired her up for the first time .................. :proud:
#6 Cooperman
  • 23,278 posts
Posted 26 June 2013 - 06:40 PM
A good quality oil, like Valvolene Racing 20w50, Millers, Penrite, etc, have all the ingredients needed for a Mini engine & gearbox.
#7 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 27 June 2013 - 12:07 AM
anything that contains PTFE (polytetraflouroethylene) isn't suitable for use in an engine.
speak to dupont and ask them what they think of using teflon in an engine.
#8 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 27 June 2013 - 12:26 AM
The tappet faces can also spall, making it impossible to set the clearances.
#9 tiger99
tiger99
  • 8,584 posts
Posted 27 June 2013 - 11:52 AM
Thanks for reminding me of the name of the stuff which completely trashed my 998 many years ago. It made the metalling peel off the bearing shells, so the crankshaft looked like a ploughed field. The hydrofluoric acid produced as it decomposed in the engine cleaned the inside of the transmission case to fresher than new condition, but did massive damage elsewhere. After fitting a new engine, the final drive pinion bearing, never disturbed by me, failed. The cage broke up, and caused the final drive to wedge tightly under load. I believe that very dangerous condition was also caused buy the acid etch.
The stuff is downright dangerous and should be banned. It was sold at the time as being suitable for engines.
#10 venkman
venkman
  • 452 posts
Posted 28 June 2013 - 05:00 PM
Well i will deffo be leaving that stuff alone thats for sure Thanks!!!!
#11 tiger99
tiger99
  • 8,584 posts
Posted 29 June 2013 - 12:22 AM
If you do think that you want some kind of additive, try the Millers Oil web site. They have proper oils for classic cars such as Minis, including combined engine/gearbox, and they have a very good reputation.
#12 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 29 June 2013 - 04:07 AM
If an oil needed an additive - why don't the manufacturers add it as standard?
I agree that the best thing to do is just to buy a proper oil in the first place. There are times when less is more.
Edited by Captain Mainwaring, 29 June 2013 - 04:07 AM.
#13 racingbob
racingbob
  • 3,061 posts
Posted 29 June 2013 - 10:07 AM
ive been using something called MPG extreme in my engines for many years
starting using it when lived in AUS in my road car done 100,000 klms with it in
no problems, so thought would put in my mini only done 7000 miles
with it in no problems tho.
the US army used it there vehicles during the Gulf war both
engines and gearboxes, certainly quietens engine
no Teflon, its thin stuff not like stp
its pretty expensive more than the oil
#14 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 29 June 2013 - 10:56 AM
I've got 280K Miles on a V6 Pajero that's only ever had regular oil changes -
Reading the manufacturer's data...I'm not sure I want to try it.
When decomposed by heat is produces hydrochloric acid in the presence of water.
MPG EXTreme PLUS™ is designed for conditioning the metal crankshaft, connecting rods, and allied parts of an internal-combustion engine.
#15 racingbob
racingbob
  • 3,061 posts
Posted 29 June 2013 - 12:52 PM
its also recommended for gearboxes
if the US army put it in there vehicles good enough for me
I use it not telling anyone else to, I don't sell it
my Hyundai accent in AUS done over 100,000 miles.
with it in the last 60,000
ran great had it in that
gearbox in my mini great ( touch wood as my mum always said)
