vauxhall 2L 16v project
132 replies to this topic
#61 maph2
maph2
  • 1,291 posts
  • Local Club: Poor Boys Warwick
Posted 12 July 2007 - 09:09 AM
Looks like a nice project :P
Do you know how wide the group 6 arches are? Because im looking for some arches to fit over my 6x10 with an inch spacer lol
if you have a look at the pic showinfg the side of the clubby, you can see that these arches only just cover my wheels - and those wheels are 7x13's. theses arches will probably be too wide for 6's. you'ed be better going for grp2 "wide" if you want the tyre nicely covered or the narrower standard grp 2's if you like a bit of "poke"
personly, i'd go with minispares standard grp 2 arches with 6x10's
Edited by maph2, 12 July 2007 - 09:11 AM.
#62 maph2
maph2
  • 1,291 posts
Posted 09 August 2007 - 03:23 PM
tis now on the road after passing its MOT last weekend. is booked in for a tune next week ready for a shakedown run to MITP
, the n on to germany for BH2N on the 29th. some update pics:-
side view
stickers:-
boot floor/backbox:-
interior - door cards will be a biscuit colour with matching carpet:-
messy wiring and bulkhead needs sealing:-
#63 maph2
maph2
  • 1,291 posts
Posted 10 March 2008 - 11:54 AM
well, its been a while since my last post. the mini didn't go on the BH2n last august as it wasn't set up to do the journey. and to be honest, its sat in the garage untouched up to january this year. i took it to Northampton motorsport for a map and suspension setup.
Basicially the suspension was set up, corner weights etc although the the rear toe couldn't be done due to limited adjustment in the (s)huddersfield rear beam (what a POS, don't buy)). one of my next jobs is to sort this - a simple job of redrilling the inner radius arm brackets closer to the heel board.
the remapping didn't go well - NM checked and adjusted the timing belt, set the ignition maps and balanced the Tb's but couldn't map as the engine ecu temp sensor was registering a massive temp spike when a power run was attempted.
they said the fiat uno rad was big enough for the engine (its quite small, core is 32cm x30cm) but some things have been identified to sort out the temp spike:-
- header tank wasn't high enough, so the cylinder head wasn't full of water. the spike was caused by steam near the ecu temp sensor. i've now got a metro header tank which is a better shape to get it higher than the engine.
- i need to put a 1mm hole in the thermostat so allow some pre warm up percolation and to allow trapped air to escape
- i have tapped a small take off into the main coolant pipe (cyl head to rad). this is the highest point of the plumbing other the header tank. i'll run a pipe from this to the header tank so air can purge out (like on modern car systems).
- the chap at northampton motorsport advised that i should reinstate the water take off in the inlet manifold as this will help cyl head temps. i sourced a pair of ally inserts with 15mm takeoff to go in the rear coolant pipe. these will connect the inlet manifold takeoff and also the plumbing for the heater.
Once all that is done, i will mount the rad correctly and chop the front panel so maximise air flow to the rad.
pics to follow....
#64 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 10 March 2008 - 12:46 PM
Hi Maph, what rear radius arms are they?
Great project, hope you get it sorted soon!
#65 maph2
maph2
  • 1,291 posts
Posted 10 March 2008 - 01:49 PM
not sure who made them - were bought in a job lot from a stillborn hillclimb project about 3 yrs ago. i think the company is london way. i did find the website but can't remember
#66 maph2
maph2
  • 1,291 posts
Posted 08 July 2008 - 07:15 AM
Now mapped ands fuelling properly. was RR'ed at 150.6bhp at the fly and 136lbft torque. power is down by 10-15bhp IMO, due to the injectors either maxing out or are low impedance. more like that they are at full flow and the power graph showed no drop off at 150.
me a happy bunny though as i can now drive it and move on to tweaking the suspension and sorting the bodywork.
Edited by maph2, 08 July 2008 - 07:27 AM.
#67 maph2
maph2
  • 1,291 posts
Posted 09 August 2008 - 01:15 PM
this is in the summer 08 latest issue of mini magazine, taken at gaydon mini festival last month
#68 maph2
maph2
  • 1,291 posts
Posted 15 August 2008 - 07:32 AM
cibies now installed and some proper bonnet pins to hold the bonnet down:-
#69 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 18 August 2008 - 02:23 PM
sweeet.... whats the allspeed frame made with?
#70 maph2
maph2
  • 1,291 posts
Posted 18 August 2008 - 05:00 PM
well, its steel mainly, but glued together with a special fruit-based resin thats a secret recipe.....
Edited by maph2, 18 August 2008 - 05:00 PM.
#71 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 19 August 2008 - 08:18 AM
sounds like it could be a hubba bubba nightmare.....
#72 Jackman
Jackman
  • 4,053 posts
Posted 19 August 2008 - 02:47 PM
Do you have any idea of this secret recipe, make make restoring my estate cheaper.
#73 maph2
maph2
  • 1,291 posts
Posted 19 August 2008 - 02:55 PM
#74 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 19 August 2008 - 03:15 PM
#75 maph2
maph2
  • 1,291 posts
Posted 04 September 2008 - 11:56 AM
