vauxhall 2L 16v project
#46
Posted 05 January 2007 - 05:27 PM
#47
Posted 10 January 2007 - 02:40 PM
Posted 10 January 2007 - 06:20 PM
Posted 10 January 2007 - 06:21 PM
#50
Posted 12 January 2007 - 06:27 PM
Posted 13 January 2007 - 09:53 PM
hi maph its miff, sounds like a double act ! have you thought of using a bigger radiator? i used an astra gte rad and it`s a lovely fit, also have you thought about moving the brake master to the other side of the car,(miffs mental mini pictures) just a suggestion, top build mate, 2l vauxhall the only way to go, MIFF.made a bit more progress with weekend. the manifold has been a bit of a buqqer. eventually had to lift the engine to get it on. also had to trim the front sunframe brace as well, which i'll reweld up to restore strength.
started to fabricate thr alternator bracket. went to my local hardware shop and got some 90degree brackets and some 2mm thick steel strip. it'll be tight for the alt but seems to go in with plenty of room to allow tensioning of the belt.
have decided to go with the mpi rad which i think will be ok
#52
Posted 14 January 2007 - 03:29 PM
have a got a corsa rad in the gargae but will stick with the mpi one for now (will be running water wetter/no antifreeze). can't ar$ed to move the master cylinder as i've got plenty of room - have sourced an ultra slim fit filter so no issues there.
#53
Posted 29 January 2007 - 06:54 PM
Posted 30 January 2007 - 08:47 AM
#55
Posted 30 January 2007 - 04:20 PM
#56
Posted 30 January 2007 - 05:33 PM
#57
Posted 02 February 2007 - 06:05 PM
Posted 11 July 2007 - 06:18 PM
#59
Posted 11 July 2007 - 06:24 PM
Looking forward to seeing this on the bh2n run.
#60
Posted 11 July 2007 - 07:33 PM
Do you know how wide the group 6 arches are? Because im looking for some arches to fit over my 6x10 with an inch spacer lol
