hi i have a squeaky clutch pedal every time i release the pedal i have tried some wd40 on it but only lasted a day and it come back. anyone else had this before?
Edited by ToM 2012, 20 June 2013 - 09:04 PM.
Posted 20 June 2013 - 09:03 PM
Posted 20 June 2013 - 09:48 PM
Did you spray the pedal bush area and the clevis pin ? not the best thing to get out but check the rubber on the bottom of the master cylinder before you strip it, try oil as it from memory has a nylon bush in the pedal ?? and wd40 does wear off nylon
Posted 20 June 2013 - 09:55 PM
i sprayed it over the return spring? if i can get my hand up there do you reckon put some multipurpose grease around it? the master cylinder is brand new and the set up.the only thing i am using original is the pedal box. thanks tom
Edited by ToM 2012, 20 June 2013 - 09:56 PM.
Posted 20 June 2013 - 09:59 PM
It will be the bush in the clutch pedal that's run dry of grease or a tiny mouse...
Posted 20 June 2013 - 10:00 PM
Got to be something which will soak in if its the pedal pivot unless your taking it apart
Posted 20 June 2013 - 10:52 PM
Im afraid its the big spring on the pedal, can you check if the noise is coming from the spring?
Posted 20 June 2013 - 11:07 PM
My god mine does this and it drives me nuts!
I spray it with 3 in 1 oil once a fortnight but it only last so long. Thing i'll have to try something thicker and try and work it in more
Posted 21 June 2013 - 05:45 PM
i hope there is not a mouse in there lol cheers
Posted 21 June 2013 - 05:46 PM
hi i want to try to avoid taking it apart as its not an easy job to do. ile give it a good greasing while my heater box is out the way. cheers
Posted 21 June 2013 - 05:47 PM
hi i think its the spring it stopped the other day when i sprayed wd40 on it but now its back again.
ile be taking some 3in1 with me on my trip then just incase lol cheers
Posted 21 June 2013 - 07:45 PM
if its the spring then good luck, tried WD40 once myself with no avail
Posted 21 June 2013 - 07:53 PM
if there is lets hope it doesn't start eating it's way through any wires...
Posted 21 June 2013 - 08:55 PM
mouse trap set up tomoz.
