Mate, the only time a new build have to run at idle, is when you bed in the camshaft at its first start up, and you do that idling at 2k-3.5k rpm
You need to put load on it, thats where you get the actual vacuum from the engine, also the depression in the carb is different under load
No point of letting it idle and watching the AFR gauge going up and down, you can potentially flood the engine and glaze the bores...
