OK, I think I'm officially stumped. Plan_B... I've found where I can borrow an HIF44 and dizzy from so will give them a try soon (i.e. to eliminate/verify if my own carb or mj ignition is the cause).
So what did I do today?...
- Leakdown test. All cylinders look good showing no more than 15% leak down. On the plus side I did find that I have a slight leak in the exhaust (at the clamp between link pipe and rear box)
- Rechecked that the timing was referenced OK (i.e. disconnect megajolt so the EDIS is in limp-home mode) and using a strobe the timing was rock solid at 10deg independent of rpm
- Last night I went looking for leaks in the carb/manifold. Sprayed a LOAD of easy start around the carb and found the revs change every so slightly when spraying the WOK side of the carb near the abutment plate. However it was drop in rpm (not a rise) and now in hindsight I think the rpm change was either overspary getting into the air filter or maybe because i sprayed the carb body with so much of the stuff it was getting cold and trying to ice???
- Trying to chase down the above 'psuedo-leak' I took off the carb and inlet manifold. I couldn't find any indication of bad seals or gaskets between the carb, spacer, manifold, or head.
AFR is still bouncing around and too rich, and inlet pressure is fluttering (megajolt MAP sensor is showing 50kPA with a +/-5kPA flutter at 950rmp lopey idle... and doesn't really improve if I take idle up to e.g. 1200rpm 1200rpm).
So here's hoping the carb I borrow behaves better, and if so then I'll ship my other one from the UK in the hope that it behaves better.
To answer other questions:
Earwax: Breather is capped, but I haven't bother disconnecting (and capping) the vacuum take off... with the vac disconnected it wouldn't make any difference to timing as the megajolt map is set for similar advance at 50kPA (idle) and 100kPA (i.e. MAP sensor disconnected and open to air)
Jaydee: Yes I do understand that once run in I'll want to set the mix slightly on the rich side... but I'm not that far yet (car still hasn't been out for a proper run... too much risk/paranoia that doing so will reck this newly built engine... so the only real live engine time it;s seen is sitting in the garage trying to diagnose this problem). As for dashpot oil... I did change from 3-in-1 to 20W50 a few days ago but as expected that made no difference to the 'stall after throttle blip' problem.
So say tuned to see how I get on with a loaner carb and dizzy...
