1992 Rover Mini
Standard 8.4" discs with EBC Ultimax pads
I've had this issue since buying the car, solved for a bit after fitting new discs but it keeps coming back.
I originally bought a new set of discs and pads from Minispares to try and get rid of this vibration. Put them on, and I think it was ok for a bit, but then came back. Took it to a local mini place, and they ran the discs up on a lathe to check the run out, which turned out to be well over the maximum, also found out my drive flanges weren't quite flat either, so they skimmed a touch off them to flatten them out too. Bought a new set of discs from them and refitted everything.
Problem seemed to clear up then, but it came back after a few hundred miles, and steadily got worse.
It only seems to happen under light braking, if I press the pedal harder, it's fine, plenty of braking and nice and straight, but under light braking, like gently slowing down for a junction or whatever under normal driving, the wheel really vibrates.
I know my column bushes are pretty worn, as when the cars stationary, I can move the steering wheel about (up/down and left/right), and I can see the inner shaft moving but not the outer one. I'm going to look into changing these and getting them sorted soon.
I've had the wheels off and worked the calipers, which are refurb'd ones bought from here about a year ago, the pistons still look brand new and they move easily and pretty evenly in the caliper. The pads don't seem to be binding either.
Going to be checking the run out on the discs in the next day or two to see if the discs have warped.
The engine steady bushes were replaced about a year ago, and both still look fine and there's hardly any play when trying to rock the engine.
It's got Minispares adjustable tie rods, with the rubber/poly bush setup, and adjustable lower arms with the offset bushes. Nothing looked broken when I had the wheels off the other week, and the tracking is about right, it may be a little too much toed out on the fronts but not by much.
The u bolts holding the rack all seem okay, and the pinch bolt at the bottom of the column is not loose.
I'm after any other suggestions of things to check while I'm at it, other ideas on what could be causing this as it's getting annoying and I'd like to get it sorted.
