hopefully by end should be black on the exterior with white 1275gt vinyl then a white leather interior with black stitching
1275Gt --First Mini Project
#16
Posted 12 June 2013 - 10:00 PM
#17
Posted 12 June 2013 - 10:04 PM
I would get the engine and subframes out first.
Brace it up internally then get it on a spit. That will make your life so much easier.
#18
Posted 12 June 2013 - 10:09 PM
mini is being moved into my garage soon soo looks like im going to do that just before that,
have loads of parts to clean up and deceiver what they are so that will take the rest of my week then the restoration begins
#19
Posted 12 June 2013 - 10:37 PM
to tackle the large amount of surface rust ( & to save money) was searching around on ways of doing it myself and i found this , obviously bit more complicated but its too late to type full thing out ...
Basically use steel wool first and rub the whole car down ...
then apply vinegar water & leave for 10 mins
wash off by hand & dry by hand
then spray with an Anti-rust primer..
Any thoughts ?
#20
Posted 13 June 2013 - 06:56 PM
Regarding the surface rusting. Vinegar does apparantly work although I've not tried it myself as I think it will take too long. It seems several days soaking, suitable for small parts only I'd say. You could try citric acid and wallpaper paste covered with clingfilm (24hours)
If the surface rust is very light phosphoric acid would work, something like rustbusters phosclean B. I prefer to use rust removers rather than rust convertors.
Take a look at my build thread if your interested in rust. I had some heavy rust under the drip rails on my mkII and have some after treatment pics, also did some research on different paint.
Ollie
#21
Posted 13 June 2013 - 06:59 PM
#22
Posted 13 June 2013 - 07:00 PM
Bonnet half restored
Started rubbdown
Engine breakdown tommos as now have a haynes manual
#23
Posted 13 June 2013 - 07:18 PM
Look's like a good project, What year is it? Is it a genuine GT?
For your pictures I would create a photobucket account and copy the IMG code in to your posts.
#24
Posted 13 June 2013 - 07:49 PM
Good luck with the project.:)
#25
Posted 13 June 2013 - 09:17 PM
M1n1mad -- cheers , should be great when finished
#26
#27
Posted 14 June 2013 - 10:28 AM
#28
Posted 14 June 2013 - 06:05 PM
Gotta leave it for a bit due to exams but i know i probably wont
#29
Posted 14 June 2013 - 08:11 PM
#30
Posted 14 June 2013 - 08:14 PM
Small update : should be picking up grille tomorrow
