Driving home late last night, about 6 miles from home, my charging/battery light came on at full brightness. Revs didn't impact the light, and it remained on for the rest of the drive home. This afternoon, I've ran a few tests and am leaning toward a dead alternator but I do have one question mark hanging over that diagnosis. According to KernowCooper's "Alternator & Charging Wiring-Basic Tests" post (http://www.theminifo...test alternator), everything goes along with his steps until step 7.
At step 7, he states that with the ignition in the ON position, the third (small) wire on the back of the alternator should read 12+v. I get a around 1.4v, and that is what is confusing me. Should I indeed be getting 12v or more on that connection with the engine off but ignition set to ON?
With the engine at 2k RPM I'm only getting 12.4v at the battery (12.56v with the engine off), which is obviously what is pushing me toward having a bad alternator. The battery is about a month old, FYI. On the back of the alternator, with the engine running, I get the same 12.4v on both of the large connectors.
So, do I have some sort of wiring issue somewhere, or is the 1.4v reading on the small connector not important to the issue. For the record, the car is an '87 Advantage with a pre-84 Metro 1275. As always, any help offered is greatly appreciated!
Seth
