Thanks for the advice Petrol.
Update
I removed the n/s over sill today as I managed to get an angle grinder. It revealed lots of rot and I have decided that I will replace both the inner and outer sills.
As I wanted to have the inner sill as one whole section rather than lots of patches, I cut the inner sill section off the floorpan.
The bottom of the bulkhead where it meets the inner wing is very corroded so I'm going to chop that off and use the section in the floorpan to replace it. I will be replacing both inner wings as the shock mounts are rotten through and toward the bottom they are corroded so they're not worth saving. Also, the passenger's side one has been patched and there looks to be about 4 layers of metal on one particular area.
In this photo you can see how the floorpan will patch the corroded section in the bulkhead
On the driver's side, the floorpan has been welded over the top of existing corrosion so that will be cut out, trimmed and welded back in place. I will also replace both sills on that side as the inner sill is currently just lots of patches.
I have also finally finished removing the bitumen sound proofing from the floor and rear seat, here is a picture of it wire brushed and, once the sills and floorpans are fixed, ready for some primer.
While on the subject of paint, what would you say is the best way to paint all the metal? Red Oxide, Primer, then top coat? For the bits that won't necessarily be seen, I was going to use Hammerite for the top coat. Using the hammered finish and WaxOyl for the bottom of the car. What are your thoughts?
Oh yes, I also did a bit more welding practice, this time on thinner cleaner metal.
It's still rubbish, I know, but I would like to think I am getting better. With the addition of an auto dimming mask, I hope that it will be easier to place the torch in the right place, as at the moment, I seem to keep welding in the wrong place.
Thanks for reading everyone, and please keep posting your comments!
Edited by HarrysMini, 14 June 2013 - 08:05 PM.
