1989 30, 12X6 Mambas, Special Arches, Rub And Poke ?
5 replies to this topic
#1 stretch tech
stretch tech
  • 1,363 posts
  • Local Club: A5 & Mini Mainiacs
Posted 10 June 2013 - 01:05 PM
hi all, i've fallen smitten to a set of gold 12x6 mambas for my thirty and some 165/60/12 tyres (possibly A532's)
i currently have a set of gold 12x5 supalites with 145/70/12 tyres with standard rover special arches and on full lock on uneven ground they just about touch the wing
will these new wheels/tyres rub any more than present ? they are wider but slightly shorter so maybe this would cancel out ??
also how far will they stick out from the arches ? i like wheel poke but i don't want anything ridiculous - a thirty has spaced drums and discs so will be wider than on a drums all round mini if that helps
Rhys
#2 jb93
jb93
  • 2,439 posts
Posted 10 June 2013 - 08:00 PM
Yep, they will rub quite a lot. This is all relative to your ride height, I run 6x12 supalites and had to trim the arches/front panel quite a lot.
They will poke a bit as well, this pic might give you a better idea...
#3 stretch tech
stretch tech
  • 1,363 posts
Posted 10 June 2013 - 08:50 PM
i've got wedge stance with my fronts nearly on bump stops when i sit in it atm and tyres rub sometimes on full lock
that said that looks b-e-a-utiful  :gimme: i love the wheel poke, do you get much hassle from the old bill and mots etc with that set up ?
Rhys
#4 jb93
jb93
  • 2,439 posts
Posted 11 June 2013 - 06:25 PM
I didn't really use it enough to have any bother from the po, but it just got dirty to the point where it needed washing all the time, which annoyed me.
#5 stretch tech
stretch tech
  • 1,363 posts
Posted 13 June 2013 - 07:16 PM
hmmm i don't want to have to wash it even more often than i already do :L i really like the 12x6 mambas but i don't want to put wider arches on it either .....
#6 998kid
998kid
  • 473 posts
  • Local Club: Essex Mini Club
Posted 11 July 2013 - 08:45 PM
Neggy camber will bring poke in a bit ;)
Edited by 998kid, 11 July 2013 - 08:46 PM.
