I Only Wanted The Wheels....
clubman
505 replies to this topic
#391 keefr22
keefr22
  • 591 posts
Posted 01 October 2014 - 09:37 PM
So not much to update as I've been pretty ill lately! May of got 2 more stickers though....
I'm not 100% on them so I'm expecting some stick for them!
OK, here's some - stick, stick, stick....!!!
#392 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 06 October 2014 - 09:33 AM
It's a no from me....
#393 72clubman
72clubman
  • 443 posts
  • Local Club: Charnwood Minis
Posted 06 October 2014 - 06:33 PM
I'm still undecided...
We'll see.
So yet another busy weekend miniing!
I've always struggled taking passengers as over any reasonable bump I burn my rear tyres on the inner arches!
So off it came!
mmmmmmm I love my minifins.
Old Knackered cones vs new ones.
The old (I'm assuming original) Cones where very attached to their homes, and shed the rubber leaving the metal housings on the trumpet and subframe. The Subframe side was easy. One large tap and the cup popped out. The trumpet side on the other hand would not budge.
In the end after heating, hammering, and far too much penetrating fluid I had to resort to the angle grinder. Cut the tops off the cups and then carefully slotted the remains. Managed to liberate the trumpets with no damage!
Liberated trumpet.
Had a little trouble with one of the nylon cups. It would seem one arm got refurbished, one didn't.
Much swearing occurred.
Also had new built up knuckles with new cups, just because it would be silly not too.
Aaaaaaaaand back down on the ground.
Now thats a properly stanced mini.
I then went to meet up with someone I met at Stanford Hall. Also an avid Mini Challenge fan.
He thought my car may have been an ex-challenge car! So my plan succeeded.
Ended up talking for ages about the race series and 1275 GT's.
He even provided this....
coming to a certain GT very soon.
Joe
#394 72clubman
72clubman
  • 443 posts
Posted 17 October 2014 - 06:12 PM
So this was the order of the day today!
I finally got fed up of driving round with what sounding like a pestle and motor in my diff!
Oh the grinding was awful.
I've become a bit of a dab hand at engine removal! Had it out in no time.
& the offending item.
So there's a bit of play!
So hopefully with this hoard
I should be able to fix it!
We'll see tomorrow.
Joe
#395 72clubman
72clubman
  • 443 posts
Posted 18 October 2014 - 07:22 PM
So the fibre washer on the OS was a little worn....
All built up with a competition diff pin, new planets, and all new washers.
Oh and a new cage and output shafts.
The old diff pin didn't seem to have any wear, the planets did, but something (maybe the bush in the diff cage) caused the output shaft to eat through the fibre washer and start on the diff cage!
I also put new diff bearings on, why not while it's out!
The crown wheel looks like it's new! As does the gearbox internals that I can see which is always nice :)
Joe
Edited by 72clubman, 18 October 2014 - 07:23 PM.
#396 keefr22
keefr22
  • 591 posts
Posted 19 October 2014 - 09:25 PM
Nice work!
#397 72clubman
72clubman
  • 443 posts
Posted 21 October 2014 - 12:23 PM
Well if anyone was wondering I managed to get it all back together on sunday evening and drove it back to where I'm living. Always a bit nerve wracking driving a car 150 miles after the engine was on the floor a couple of hours before!
While the engine was out I thought I'd address an oil leak that had reared it's head!
Just a small easy one then. Oh and my dad didn't like the look of the end core plug, he then poked a hole in the core plug with a screwdriver. It was very close to breaking through! Luckily I had a spare.
 So I do have a 3.44 diff, always nice to know for sure.
All Prepped to go back in.
The picture taking stopped at that point as it started to get a little dark.
I also put on a new gear selector coupling, as my old one you could shake! The roll pins now locate in it keeping it secure and it has improved the gearchange.
Only problem is it still has a road speed dependent noise! No fecking idea what it is. (The only thing left is something beyond the crownwheel in the gearbox (but not engine speed related) or the drivers side wheel bearing (which is rock solid) The passenger side I changed with a new hub recently.
Oh and I tried to adjust my clutch properly since I found a cracked master cylinder lid, and now it crunches again,so I need to sort that!
There's always something to do!
Drives nicely though, feels really tight and together.
Joe
Edited by 72clubman, 21 October 2014 - 12:25 PM.
#398 keefr22
keefr22
  • 591 posts
Posted 21 October 2014 - 12:37 PM
We have two substantial oil leaks in ours to sort. One is from an oil cooler pipe, so easy enough. The other is from 'somewhere in the gearbox area'. So I bet that'll be a nice small easy one too...!!
Good work in getting all that fixed, back in & driving home in a day!
Keith
#399 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 21 October 2014 - 01:45 PM
Great work. At least you're being kept busy then!
#400 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 October 2014 - 04:31 PM
excellent!
#401 MrBounce
MrBounce
  • 2,641 posts
Posted 22 October 2014 - 07:44 PM
That's some good work! I'm scared of diffs and gearboxes - have been since I managed to break a crownwheel into 3 pieces (no idea how!).
#402 Minimad100
Minimad100
  • 416 posts
Posted 22 October 2014 - 09:23 PM
I went the other month!! Very nice! Even serves beer in a chilled glass!!!!
#403 72clubman
72clubman
  • 443 posts
Posted 24 October 2014 - 12:10 PM
Thanks everyone it certainly keeping me busy.
I think I'm going to change my driverside wheel bearing just to be sure when I get a chance.
But for now it's driving nicely. I took it out for a good run after work and it really feels lovely now.
I think I need to pop into this pub! All I'm hearing is good things.
Keith
Good luck with that! I did all my seals when the engine was out of the car a few months back, but it sprung a new one!
Now that is impressive! I was very careful with mine when I had it out!
Joe
#404 72clubman
72clubman
  • 443 posts
Posted 25 October 2014 - 05:38 PM
I have been most neglectful on the cleaning front! Haven't washed the poor girl in weeks!
So it's just gratuitous pictures I'm afraid.
I also had a good clean of the interior.I do love the GT dash.
Joe
#405 keefr22
keefr22
  • 591 posts
Posted 25 October 2014 - 06:56 PM
Oops, duplicate post!
Edited by keefr22, 25 October 2014 - 06:59 PM.
Also tagged with one or more of these keywords: clubman
