I am so glad it's pulling back into shape ok.
So is the plan to do a rough repair and then continue to use it?
Ben
Posted 15 June 2014 - 10:01 PM
Ben
Posted 15 June 2014 - 10:32 PM
Sadly you're spot on!
I really want to do a proper job but I need a car really quickly and the mini is still MOT'd, taxed and insured.
It also lost it's garage space so I figured if it's going to be outside it may as well be on the road.
Make it as tidy as I can for now then hopefully do a proper job at a later date. I've already got the major plan all worked out. It's going to be comprehensive!
Joe
Posted 15 June 2014 - 10:38 PM
Joe
Now that sounds exciting.
Having followed this for so long now, i know it's going to be good.
Ben
Posted 18 June 2014 - 09:52 PM
So in my quest for a quick turn around I decided to do this.
There was quite a few oil leaks and a sheared engine steady, so I figured it was the best move since I already had the radiator out!
I've also finally finished all 4 wheels!
Damn they're pretty!
Engine gets all new gaskets and a lick of paint tomorrow.
Joe
Posted 19 June 2014 - 10:15 AM
i love how having the rad out is enough to pull the engine out, great bit about minis i suppose! looking good, straightened out fairly well
Posted 20 June 2014 - 08:08 PM
Posted 20 June 2014 - 08:39 PM
What a lovely clean motor!
Posted 21 June 2014 - 08:06 AM
Posted 21 June 2014 - 03:24 PM
Those wheels, though, Those wheeeeeeeelssss....
Posted 21 June 2014 - 05:03 PM
Posted 21 June 2014 - 09:58 PM
The motor cleaned up beautifully. Another reason for pulling the motor was a weeping core-plug, so this was duly replaced. I'm also treating and repainting everything that comes off, gotta start somewhere, and something i regret not doing last time. I also decided to repaint the motor black, I know the A+ should be red but it's more fitting of the car. I also replaced the rod stabiliser as I failed at removing it with the motor in the car. I'm Also replacing all the engine steady bushes so it shouldn't move at all.
I forgot to order pot joint seals though! So I'm just waiting on those now.
The wheels came up amazingly, spent hours with fine grade sandpaper removing all the corrosion and damaged lacquer, then polishing the faces with a fine cutting compound. Only took me 6 hours!
Joe
Posted 23 June 2014 - 10:13 PM
So today was a painting day. I also clamped the front end back in place where it had moved and teared awaiting welding tomorrow.
I winged about this before.
Brand-new Shock mount last summer.
Anyway it hadn't rusted through, so it was taken back primered and covered in paint.
New Gearbox steady mount, painted before mounting this time!
Repainted engine steadies, with sexy purple poly bushes :)
( I've only had an ultimate engine steady on for the last 6 months, dodgy I know!)
Do I refit the ultimate engine steady though when I've got these on?
I also repainted the radiator shroud, it was looking nasty!
Wheel back on.
Only to remove the hub nut mind, although without an engine it's proving challenging, I need some ballast!
Thats it for today, more tomorrow!
Joe
Posted 26 June 2014 - 09:48 PM
Today I put my immaculate engine in my crappy car.
My dad described it as a rat look, where the mechanicals are good but it looks terrible.
Laavely. I've got all my ancillaries back on with all new gaskets so I'm hoping for a leak free engine.
Just waiting on new outer CV boots that should come tomorrow, then I can reinstall my driveshafts and I'm good to go.
I did have one major set back though, while dropping the engine in I noticed the union to the left hand brake hose was wet, I inspected and it was brake fluid, so I tried to tighten the union and the pipe sheared. So I now have a structurally sound car which should be running tomorrow, but now no brakes.
I'm frantically trying to source one, I tried one from my other mini but it's a different size
Car needs to be mobile by the weekend as I'm moving and starting a new job!
Joe
Posted 28 June 2014 - 10:11 PM
Today I figured maybe a few hours and it'd be drivable. Well after 11 hours today it is! well minus sidelights.
Driveshafts were renewed with new gators.
All new engine steadies.
Engine, radiator, and heater fully flushed and all new coolant.
filled with oil, and so far leak free.
New heater take off, with a new cable.
New cross brake pipe, and new fluid.
Another million things I've probably forgotten.
Oh and 2 new headlights! as the O/S (the side that didn't get hit) was cracked into 4 pieces!
Joe
Projects →
Mini Saloons →
Black 1979 1275GtStarted by StuaR32t , 15 Feb 2025 ![]() |
Projects →
Mini Saloons →
Cape Town 🇿🇦 1275HleStarted by JAYO , 28 Feb 2021 ![]() |
Projects →
Mini Saloons →
Budget Mini Clubman Shell Restoration For £1500Started by minimissions , 13 Nov 2019 ![]() |
Projects →
Mini Saloons →
1275Gt Tarmac Rally Car - From ScratchStarted by KRM_Simon , 26 May 2019 ![]() |
Projects →
Mini Saloons →
1275Gt Resto - From Flip To FactoryStarted by Verderad , 12 Mar 2018 ![]() |
