Synthetic Or Mineral Oil?
21 replies to this topic
#1 aelx.hopwood
aelx.hopwood
  • 32 posts
Posted 06 June 2013 - 11:15 AM
Doing a resto and will be a daily driver once finished.
Checked my Haynes and I'm gonna be going with 10W40 engine oil.
It's a 998 A+ engine from the mid 80s.
The Haynes manual says that it's a tradeoff between prices, with synthetic being more expensive, but was wondering if anybody could elaborate on that?
And I take it that if i'm gonna change the oil I'll need 5L minimum?
#2 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 06 June 2013 - 11:17 AM
I believe you cna only use mineral oils as the synthetic oils damage the gear box so I ance always used halfords 20/50 I think it there classic car oil
Jack
#3 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 06 June 2013 - 11:24 AM
Mineral mineral mineral mineral mineral!
You shouldn't follow the advice from Haynes on this as the car is older now. If you are changing the filter as well I think you'll need 4.8 litres.
Halfords Classic 20w50 is perfect and fairly cheap. It's lovely and green and thick so it leaks less :proud:
#4 aelx.hopwood
aelx.hopwood
  • 32 posts
Posted 06 June 2013 - 11:28 AM
Okay, great. I'm glad I came and asked now!
20W50 it is!
By "as the car is older", do you mean that the engine will be weaker, or that synthetic oils have changed?
#5 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 06 June 2013 - 11:44 AM
20W50 it is!
Tolerances in the engine are larger than modern cars so will need a thicker oil to compensate.
Personally I recommend Millers Classic Mini Oil as it has 20W50 for the engine with additives for the gearbox. It may be more expensive but it's good stuff.
http://www.minispare...px|Back to shop
Edited by IainStallard, 06 June 2013 - 11:45 AM.
#6 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 06 June 2013 - 11:56 AM
i use the comma classic (green tin with the mini picture on it) £18 for 5L tin. i just pour the lot in as its ony 200ml so it doesnt do any damage.
#7 reallybig
reallybig
  • 613 posts
Posted 06 June 2013 - 12:15 PM
10w40 semi synth
#8 lewBlew
lewBlew
  • 1,238 posts
Posted 06 June 2013 - 12:26 PM
I think Halfords oil is made by Comma so it's probably the same stuff (not sure). But classic mineral oil is the way to go as not only is it cheaper than synthetic alternatives but it's designed for older cars with higher engine wear. Never had any problems and I've used it in MGs, Capris, Minis...
Saying that, oil = oil = oil. As long as you've got enough in there don't worry too much.
#9 jaydee
jaydee
  • 8,565 posts
Posted 06 June 2013 - 12:28 PM
You can use whatever synth or mineral you've been using for ages, the problems comes mixing these two different oils as the easter will react and cause problems to the seals. If you're always been using mineral, do an engine flush before using synth.
And both halfords and comma classic are the same oil which is VERY poor, its plenty of decent oils around (ie comma sonic, millers, valvoline etc..)
#10 jaydee
jaydee
  • 8,565 posts
Posted 06 June 2013 - 12:33 PM
Its not designed for anything belive me, its just cheap stuff with some adv on it, really poor stuff that they recicled form only god knows where and not even half decent to get an SG-SF api approvation.
Its just that all cars you mentioned are not that fussy about oils, a mini or an mg will run even with olive oil, its just that it will wear a lot camshaft and the mini gearbox.
#11 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 06 June 2013 - 12:52 PM
well, the comma classic oil has done my mate good for 30,000 miles over 6 mini's. all of these engines are still operating today, so it cant be that a bad oil surely  (i'm not arguing mate!)
Edited by cal844, 06 June 2013 - 01:15 PM.
#12 mab01uk
mab01uk
  • 12,435 posts
Posted 06 June 2013 - 05:41 PM
Always remember no modern car shares the same oil with both engine and gearbox like Mini's and older BMC/BL fwd cars........therefore whatever brand of oil you use it must have the extra gearbox additives suitable for BMC/BL transverse engines.......and only a few on sale now do.
#13 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 06 June 2013 - 05:43 PM
Halfords classic runs 10-15psi lower than comma sonic after only 1500 miles in my MGB GT. I only use comma sonic now. Millers has a superb reputation but isn't cheap.
#14 jaydee
jaydee
  • 8,565 posts
Posted 06 June 2013 - 05:59 PM
1500 miles are a lot, castrol classic was useless on my rally car after 500 miles, those so called 'classic oils' cant take any punishment and are good only for the bog standard 850 driven by the granny to tesco..
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 June 2013 - 06:15 PM
Where's the evidence ?
