Pro Motive Build In Sunny Scotland
245 replies to this topic
#181 Bat
Bat
  • 903 posts
Posted 05 August 2018 - 07:18 AM
been doing a few bits and bobs, here and there.   Managed to fix a weird little problem which was the engine switching off every time i put it in gear, linked out the neutral input to the start cut off relay but kept the neutral switch/indicator in the loop so it still works.
I have also taken the paint off the roll cage and will prime and paint it this weekend.
also got one of the door cards upholstered,not the greatest and still needs the door pull doing and fitting (the wife has been employed with her sewing machine for that)
521_FBBE3_CCDC_413_E_B7_EE_EBD57_A359087
Hi,
On bikes there's a switch on the sidestand which stops the engine when you put it in gear if the stand is still down.
That's the bit you need to bypass.
Cheers  :proud:
#182 thespikeyone
thespikeyone
  • 237 posts
  • Local Club: none yet
Posted 05 August 2018 - 10:58 AM
Linking out the sidestand switch and the clutch switch was the first thing I done on the loom but it was still doing it even with these linked out. All sorted now tho.
#183 thespikeyone
thespikeyone
  • 237 posts
Posted 23 August 2018 - 08:07 PM
Got the dash back today and to say I’m happy with it is a huge understatement!!!!! Del at Optimus in Rutherglen http://optimustrimmers.co.uk has done an amazing job. Not only because he was one of only 2 that would actually take on the job but his quote was half the price of the other guy!!! Anyway here is some pics.
E83_ED9_C9_DA1_E_47_D0_9_E1_D_CE0_C3967_
BD68_C761_E059_4061_9_DA2_F62_AF70_E6_D1
6_EBBDECF_791_E_44_FD_841_B_3939_FB2_FBF
29850_F85_2011_490_C_A7_A7_67_C3_EA08983
#184 Bat
Bat
  • 903 posts
Posted 23 August 2018 - 08:13 PM
Hi,
That looks the dogs danglies!
Cheers  :proud:
#185 thespikeyone
thespikeyone
  • 237 posts
Posted 25 August 2018 - 04:43 PM
dash is in and it looks rather spiffing if I do say so.
41698_F27_523_F_41_B0_923_C_6_A22_C43_F4
812_E7854_6_BB3_422_C_B27_D_AD697_FBC5_A
E296_C346_C6_A8_46_AD_88_DA_D74_C4_C59_B
AC4_B73_DC_511_B_4_FA3_B9_C9_417_D9_D0_C
#186 thespikeyone
thespikeyone
  • 237 posts
Posted 28 August 2018 - 07:05 PM
out for a wash today, will get a polish and a wax tomorrow then MOT thurs  :X
C3637_D4_C_FFEB_4_EEB_AEA4_4_BBA3440365_
7_B9_DDEE5_67_D9_4_D0_A_89_EB_A026_E4_C7
F19393_C2_55_CC_432_F_AE4_B_B9_B8_FC7_A2
#187 racerlike
racerlike
  • 430 posts
Posted 30 August 2018 - 08:34 PM
How did the Mot go?
#188 thespikeyone
thespikeyone
  • 237 posts
Posted 31 August 2018 - 09:19 PM
Passed with one advisory for rear number plate lights showing white light to the rear. An easy fix oh and a quiet word advising me the headlights are not for a right had drive car and shouldn’t be fitted, especially for its next MOT ???
#189 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 02 September 2018 - 12:59 PM
That interior is something else nice work mate
#190 thespikeyone
thespikeyone
  • 237 posts
Posted 04 September 2018 - 08:24 PM
today went ok then not well at all!!
got the wheel alignment done took it for a spin and it was nice to drive it without feeling I was gonna die.
Video
then on the way home it blew the engine to filter housing oil line off and emptied its self in a dramatic cloud of smoke and hd to be trailered home.  not sure if there is any damage or not but it still turns over and starts, will check later in the week.
#191 Dracula
Dracula
    Just On Tickover
  • 6 posts
Posted 05 September 2018 - 06:34 AM
Smoke the tire not the engine :) :)  . Hope it's not so bad . Nice car . Add some stitching to the door panels and you are spot on .
#192 Dracula
Dracula
    Just On Tickover
  • 6 posts
Posted 06 September 2018 - 07:15 PM
Smoke the tire not the engine :) Very nice car . Just add some red stitching to the door panel and you are spot on .
#193 lawrence
lawrence
  • 1,340 posts
Posted 08 September 2018 - 05:28 AM
She's looking pretty dam great tho so don't get the oil problem get you down. Fingers crossed damage will be none, especially if you shut her down straight away!
#194 kubinski
kubinski
  • 11 posts
Posted 08 September 2018 - 07:53 AM
Hello thats a very wonderfull mini.
I got a promotive convertion my self.
But i have some questions.
Can you make some pictures of the oil and coolant lines so i can see where it goes and how you did connect it.
You have weld the 2 pipes on the coolant pipe at the bottem of the engine?
One of the pipes is for the heater and the other for the oil coolant but where must i connect it to.
Can you make me some pictures?
Thanks.  and keep on the good work ik wil follow you.
F9_E7_D289_479_F_45_C2_87_B1_8898016_FD1
90_E36_FDD_0_A9_F_4_AF3_BE09_7273_FB4_ED
851580_D7_B387_4_CBD_82_FF_B27982_F9_EAA
85511460_AC72_4_C3_B_AEA6_6_FB3_B4921986
hose A comes from bottom of radiator to bottom of engine
hose B goes from the welded stub on the bottom of engine to the oil cooler on the rear of the engine
hose C goes from welded stub on the bottom of engine up to the bulkhead connector then to heater inlet
hose D comes from the heater return to bulkhead connector then to the welded stub on the top engine return pipe
not shown in the pics is the large return hose which goes from thermostat to top of radiator.
hope this helps
Thanks!!!
That helps alot.
I got another question.
Where do you have your air inlet for the heater unit?
Because there is a radiator now on the promotive.
#195 thespikeyone
thespikeyone
  • 237 posts
Posted 10 September 2018 - 08:17 PM
That helps alot.
I dont have a fresh air inlet for my heater it just uses cabin air, my heater is really only there for de-mist.
