Pro Motive Build In Sunny Scotland
245 replies to this topic
#166 thespikeyone
thespikeyone
  • 237 posts
  • Local Club: none yet
Posted 11 May 2018 - 07:23 PM
been doing a few bits and bobs, here and there.   Managed to fix a weird little problem which was the engine switching off every time i put it in gear, linked out the neutral input to the start cut off relay but kept the neutral switch/indicator in the loop so it still works.
I have also taken the paint off the roll cage and will prime and paint it this weekend.
also got one of the door cards upholstered,not the greatest and still needs the door pull doing and fitting (the wife has been employed with her sewing machine for that)
521_FBBE3_CCDC_413_E_B7_EE_EBD57_A359087
#167 thespikeyone
thespikeyone
  • 237 posts
Posted 13 May 2018 - 05:19 PM
Got the roll cage done.  here is a before and after
Before: white and sh1te
0_AD02_FA7_1_D74_4985_AC62_2_AB028413_AA
After: metallic black and sexy
5877695_B_5202_42_D0_9_F17_FDE8_E3431_EE
Also learned that when making door cards to put the seals etc on the door before measuring!!!!! had to un-upholster the one i done to trim a bit off it then re-upholster it! Doh!!
#168 thespikeyone
thespikeyone
  • 237 posts
Posted 20 May 2018 - 06:53 PM
So this weekend i colour sand and buffed the roll cage then fitted it into the car, upholstered the drivers side door card done a few bits of the rear cabin stuff too.  And with the help of my very clever and talented wife we managed to get the passengers side door pull all trimmed up and I am really pleased with the way it turned out.
A5904_AD4_B5_C1_4_FF6_AA60_9_C5_F1_DA015
09_AC82_E5_E3_EE_4744_9_C7_A_B1562342_CB
BD8_A142_B_91_A8_42_AA_AE8_D_2_C8_B756_D
#169 racerlike
racerlike
  • 437 posts
Posted 21 May 2018 - 08:31 AM
That looks really good. Patience and obviously a lot of skill required. Upholstery is damn hard to get just right. I recently retrimmed the door cards in my Evo and its not an experience Id like to revisit in a hurry!
#170 thespikeyone
thespikeyone
  • 237 posts
Posted 21 May 2018 - 06:47 PM
yes it's not the easiest thing at all.  really have no idea how i am going to do the dash.  might have to pay someone to do that particular piece.
#171 thespikeyone
thespikeyone
  • 237 posts
Posted 27 May 2018 - 05:01 PM
got a few more bits upholstered this weekend.
Drivers door pull
DBC01_E20_F4_EF_49_F6_B155_D6_C3_EF6126_
Instrument binnicle
DBCC1_CEC_CE91_4652_8_A3_B_F5444_F551_F3
and the rear back pieces
C769_B448_7_C4_C_4402_BE16_55_BE566_ACD5
getting there.
#172 thespikeyone
thespikeyone
  • 237 posts
Posted 02 June 2018 - 08:04 PM
got some more of the rear cabin done and even got a wee bit of carpet down too
287559_CF_76_D4_4_CD0_84_F7_3_B69118_F02
B53_DF7_ED_1_CE0_4_C30_B859_BAE6832_EAD3
#173 thespikeyone
thespikeyone
  • 237 posts
Posted 10 June 2018 - 06:09 PM
centre console now done
C0132_C3_A_6_FD3_4970_891_E_B8_C2_A700_B
#174 racerlike
racerlike
  • 437 posts
Posted 11 June 2018 - 04:35 PM
Nice work.
Bet that was fun to do!
#175 iSonic
iSonic
  • 34 posts
Posted 27 June 2018 - 05:34 PM
Where did you get those buttons on the centre console?
#176 thespikeyone
thespikeyone
  • 237 posts
Posted 28 June 2018 - 10:43 PM
ebay atozautostyling.  not cheap or the best of quality to be honest but they do look good.  the little metal discs with the shapes fall off quite easy (had to glue a  few back on already and i havent driven the car!!) and the pins on the back bend very easy.
#177 kubinski
kubinski
  • 11 posts
Posted 01 July 2018 - 08:30 PM
Hello thats a very wonderfull mini.
I got a promotive convertion my self.
But i have some questions.
Can you make some pictures of the oil and coolant lines so i can see where it goes and how you did connect it.
You have weld the 2 pipes on the coolant pipe at the bottem of the engine?
One of the pipes is for the heater and the other for the oil coolant but where must i connect it to.
Can you make me some pictures?
Thanks.  and keep on the good work ik wil follow you.
#178 thespikeyone
thespikeyone
  • 237 posts
Posted 07 July 2018 - 09:22 PM
I will try and get some pictures tomorrow,
yes you need to weld 2 pipes on the bottom.   the radiator goes to the big one, one of the small ones goes around to the back of the engine to the oil cooler. the other goes to your heater then from the heater to the pipe welded on at the top of the engine near the thermostat.
#179 thespikeyone
thespikeyone
  • 237 posts
Posted 08 July 2018 - 05:00 PM
F9_E7_D289_479_F_45_C2_87_B1_8898016_FD1
90_E36_FDD_0_A9_F_4_AF3_BE09_7273_FB4_ED
851580_D7_B387_4_CBD_82_FF_B27982_F9_EAA
85511460_AC72_4_C3_B_AEA6_6_FB3_B4921986
hose A comes from bottom of radiator to bottom of engine
hose B goes from the welded stub on the bottom of engine to the oil cooler on the rear of the engine
hose C goes from welded stub on the bottom of engine up to the bulkhead connector then to heater inlet
hose D comes from the heater return to bulkhead connector then to the welded stub on the top engine return pipe
not shown in the pics is the large return hose which goes from thermostat to top of radiator.
hope this helps
#180 thespikeyone
thespikeyone
  • 237 posts
Posted 04 August 2018 - 08:08 PM
so i am still waiting on the dash coming back from upholsterer so been doing a few bits and bobs.  Had to re-do some of the upholstery due to ******* glue coming off so bought some 3m stuff which is much better.
chairs and seatbelts are in
9_A3_A8_EB8_15_A4_4_F2_E_BD30_6_ACEACB6_
got gear knob and home made gaiter in and fitted new carbon handbrake handle
B2_B07_ABC_5_B2_B_4156_953_E_B70_DEFD39_
B5_A2_B689_ED29_49_C1_8_C8_A_402_A658_E2
F7831063_860_F_453_D_94_EC_8_EF87_A5_AAD
Also fitted some storage nets to console to keep my phone in when it is hooked up to my apple car play head unit.
when the dash comes back it will be mot time then i will get the geometry set and aligned and engine dino'd and hopefully get to drive it before the end of the month!!
