Pro Motive Build In Sunny Scotland
245 replies to this topic
#151 thespikeyone
thespikeyone
  • 237 posts
  • Local Club: none yet
Posted 29 December 2017 - 08:28 PM
was going to do a bit more wiring tonight after work but Sanza decided she would test the car out for size instead
B496_CDAA_A82_E_44_FE_88_D7_715_CC45_A79
No room for me so I guess i will just go drink some beer.
#152 thespikeyone
thespikeyone
  • 237 posts
Posted 14 January 2018 - 06:56 PM
done some more wiring and got some parts back from daventry metal finishers and what a fine job they have done too they look awesome.
3184_E850_A6_E5_496_D_BF23_10401_F181_BD
I also fitted the baffle plate
FB98_E924_95_F8_4643_873_F_45_DE96468170
but then when i went to fit the sump the low oil switch was fouling the plate, I then read the instructions which said you should chop theswitch and just use it as a plug but i decided i wanted it to remain so drilled a hole in the plate.
Engine has now been fitted to frame for hopefully the last time, just waiting on the zorst coming back from zircotec getting it ceramic coated instead of using the wrap. then i can get the frame in the car
#153 thespikeyone
thespikeyone
  • 237 posts
Posted 28 January 2018 - 06:28 PM
Still waiting on zorst coming back from zircotec so decided to fit some of the bits to the arse end so they are not laying around the garage
03_E2_E6_C0_6165_4_A43_8835_995_E4003_F7
put a new seal in the boot which is making the boot lid stick out a wee bit at the top but hopefully the seal will bed in a bit and it'll be ok.  I should have the pipe back this week so should get the engine in next weekend.
#154 thespikeyone
thespikeyone
  • 237 posts
Posted 01 February 2018 - 08:12 PM
got the zorst back from zircotec
26_A880_A0_569_E_4_B23_B241_1856_BBA47_E
everything has now been fitted back onto the frame and ready for the final bolt in tomorrow
1_B80_F4_D3_B8_B0_43_F3_8_D84_3_DBC1_E74
#155 thespikeyone
thespikeyone
  • 237 posts
Posted 04 February 2018 - 06:15 PM
good progress this weekend, got the front frame in front brakes in, clutch line done fuel lines in, rad and plumbing done (apart from heater hoses) and tidied up the wiring.  got a wee bit more to do then the engine bay is complete.
A77_B8_BB4_8_A19_45_BA_9261_CA87_E16_B8_
#156 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 05 February 2018 - 04:36 PM
Very very nice...
#157 thespikeyone
thespikeyone
  • 237 posts
Posted 13 February 2018 - 08:36 PM
Got my new powder coated rear subframe in at the weekend.  had to wrestle with it a bit to get it in and the adjustable camber brackets were a pig to fit!!!
72_B87_BDA_622_B_4886_A13_E_744_EB281_A5
Also got the fuel lines and filter in
A11_A080_C_DDD7_4_AAC_8_DD2_576220672020
then fitted the rather yummy brakes
502_D6545_2_EB0_4892_8_BC2_CE9_DF51_CCEB
starting to run out of things to do!!!!! thats most of the mechanicals done.
#158 thespikeyone
thespikeyone
  • 237 posts
Posted 25 February 2018 - 07:58 PM
so the past week ive been finishing up a few jobs but today i couldnt resist firing it up.  Its very loud without an exhaust on it!!!!
#159 miniadventure
miniadventure
  • 724 posts
Posted 26 February 2018 - 09:11 PM
Looks good, not long till its tearing up the road.
#160 thespikeyone
thespikeyone
  • 237 posts
Posted 18 March 2018 - 06:38 PM
a wee update for those that are interested.
I have spent a wee while sorting out the last bits of wiring and trying to fix a problem.  The engine was really hard to crank, i thought it was juat a flat battery so put a new one in and it was still the same, checked loads of stuff but couldn't find the problem to cut a long story short I nearly set it on fire due to a bad earth!!!!! my mission to prevent rust also prevented an earth so it was earthing through the fuel pump earth!!!!!!! this is what happens when you put 190/200 amps through a 1mm cable.
FB9_F6_CF8_486_E_4_E14_9963_9_ADFA17_D4_
Its now all sorted and i'm now at the stage where i need to get the interior done.  like i've done throughout this build i'm giving it a go myself.  O_O  O_O
#161 thespikeyone
thespikeyone
  • 237 posts
Posted 31 March 2018 - 06:42 PM
Heedliner is in wasn't as bad as I thought to do and pretty happy with result.
99_E6_EC94_D0_F1_464_E_AFEA_3_FA07_D8825
F7_A556_B3_B7_CB_4_F10_9_FC5_F2_C5_AE41_
C6093620_2_F2_F_433_A_B9_DE_223408_C4984
also got my material for doing the rest of the interior.  so I covered the rear pillar covers so it will look the same as the rest.
BA42_C218_0_E4_F_4_C27_99_C1_AC85_D7_BD3
#162 thespikeyone
thespikeyone
  • 237 posts
Posted 14 April 2018 - 06:41 PM
managed to make a start on interior by doing the trim on the the a b and c pillars on passengers side.
EA778957_5_F53_4_F17_BFB3_60_B87_AB2_C75
637_DD7_CE_572_C_4_A86_92_D3_13_E2_DAC88
DE31_B2_B5_017_E_4_FB9_BABA_596_C6_F3_B2
22943_E41_C082_4_E05_8126_683007_AE562_D
fitted the rear screen and side window seals to hold everything in place then fitted to door seal which is now causing the bottom of the door to push out.
05195350_6_A6_F_454_A_B72_A_63_E015_BED2
The gap at the centre of the door seems to be really tight
825_FB428_517_B_41_F2_AF35_FBFD4_ECAB3_C
not sure what to do about it.  might buy a smaller seal for the bottom of the door
#163 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 14 April 2018 - 08:11 PM
Looking good.
How much does all that sound deadening weigh out of interest?
#164 thespikeyone
thespikeyone
  • 237 posts
Posted 14 April 2018 - 08:38 PM
Looking good.
Its 2mm silent coat which is 3kg/sq m.  I used approx 6 sq m so somewhere in the region of 18kg
#165 johnR
johnR
  • 2,297 posts
Posted 15 April 2018 - 11:01 AM
Nice work - does it need an exhaust?!!You might need a louder horn with the speed you'll be doing
